Dataset of engine control unit, customizable
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post03-08-2016, 10:47    Subject: Dataset of engine control unit, customizable Quote
Are there any experts who could write a custom dataset for an old engine control unit (ECU) for a reasonable fee?
Specifically, it's about an Audi 2.5 TDI AEL (5-cylinder engine).
Okay, I would write something like a specification document (you could also call it a "wish list"), and then the knowledgeable person would write a modified data set onto a suitable EEPROM based on that.
I would base my analysis on the original data as read from the MSG.
The wish list is not extensive and is more aimed at adapting the engine to new environmental conditions (e.g., installation of a different engine, as would be the case with the AEL) than at increasing performance.
The memory modules in the MSG are originally socketed, so no soldering is required.
The modifications do not need to be legalized, and TÜV (German technical inspection agency) compliance is not required.
chriskross
Post03-08-2016, 19:36    Subject: Dataset of engine control unit, customizable Quote
Hi, do you want a tune-up? I assume it's an EDC15.
A6 AFB
A6 BRE DPF
Post03-08-2016, 21:51    Subject: Dataset of engine control unit, customizable Quote
Jens 16syncro
Post04-08-2016, 11:00    Subject: Dataset of engine control unit, customizable Quote
chriskross wrote:
Hello, do you want a tuning?
No, I want adjustments to the mapping for the EGR system and the turbocharger boost pressure. Furthermore, a slight increase in the fuel injection volume in the lower RPM range and above 4000 RPM might be considered, along with shifting the rev limiter to higher RPMs.
What I exactly want still needs to be discussed.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Doku, n.löschb. Fehler im Motorsteuergerät 2.5l V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Rütteln nach Kaltstart Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Datensatz 1,9 TDI MKB AHU On-Board Diagnostics (OBD)
No new posts Motorsteuergerät (nach Bastelei) Werkseinstellungen setzen? On-Board Diagnostics (OBD)
No new posts Motorsteuergerät defekt, bin auf der Suche nach Ersatzge... On-Board Diagnostics (OBD)
No new posts Motorsteuergerät keine Kommunikation nach VW Update Diesel Engine Technology
