Light machine faulty?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
dondYe
Post28-09-2016, 9:35    Subject: Light machine faulty? Quote
Hello dear community,
The fan belt on my 2.0L 136 HP diesel engine has broken. Has completely gone off the rails...
I have then installed a new ABS unit and replaced the gear drive belt. The battery was charged, and everything seemed to be working again. Then, during the first kilometer of driving, it suddenly displayed an ESP error. I drove another 5 km, then parked the car and drove home several hours later. On the way back, the ESP error appeared again. After turning the engine off and on again during the drive, the error disappeared.
The next day, I drove another few hundred meters. After a short stop and restart, the battery was already noticeably weak. I had covered about a kilometer when the servo failed while turning...
Since the belt was still driving the alternator, I thought the alternator must be broken. Measuring at the battery showed a very low 11.9 volts. I had forgotten to reconnect the charging device, including the car's contacts, when I installed the alternator. As a result, there was a spark when I accidentally bumped something near the installation point with the alternator. I thought that must be the reason why the alternator was broken.
Subsequently, I obtained a used alternator and, as expected, there was no change... 11.9 volts at the battery. I then measured from B+ to battery negative... 4.9 volts. B+ to alternator housing... 4.9 volts. B+ to Engine Block...4.9 Volt.
When the engine is turned off, I measured 10.5 volts on the B+ line with a battery voltage of 12.5 volts...
Is the second alternator now also broken randomly, or could there be something else?
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post28-09-2016, 19:38    Subject: Light machine faulty? Quote
Does the charging indicator light up?
Whether your used alternator is actually defective, no one can tell you for sure; it was probably cheap. icon_rolleyes.gif
Karma: +437 / -0   Thank you, like it!
Post29-09-2016, 12:09    Subject: Light machine faulty? Quote
B+ is the positive terminal of the battery. If you don't measure the battery voltage there, then the cable is broken.
Most likely, there is a fuse somewhere that tripped due to your initial short circuit (fortunately).
Greetings
Guste
Karma: +643 / -0   Thank you, like it!
Post29-09-2016, 13:59    Subject: Light machine faulty? Quote
Fuses are typically located as strip fuses directly on the battery.
No new posts Doku A6 4B, Einparkhilfe defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Kühlwassertemp-Anzeige defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document MKB AKQ, defective timing belt tensioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lichtmaschine defekt? Diesel Engine Technology
No new posts Alternator Repair: Faulty Field Winding? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Lichtmaschine defekt nach Motorwäsche A3 ALH? Diesel Engine Technology
No new posts Lichtmaschine Diesel Engine Technology
