stolley
valeru4 likes this. |
14-09-2016, 21:18 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Hello everyone!
Today, shortly after starting my reliable Polo, the glow plug indicator light flashed briefly. I then turned off the engine and restarted it. The flashing was gone.
I have now read the error codes from the system.
Here are the entries:
Quote: | Wednesday, September 14, 2016, 23:33:10:25065
VCDS, a Windows-based VAG/VAS emulator, runs on Windows XP x86.
VCDS version: RKS 15.7.4.1
Data as of: 20160226
Vehicle Identification Number (VIN): WVWZZZ9NZ8B031xxx License plate:
Mileage: 337,980 km
Repair order: Flashing glow plug indicator.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: 9N (9N3 - Polo)
Scan: 01 03 08 09 15 17 19 25 44 46 76
Mileage: 337,980 km
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module
Label file: DRV\045-906-013-BMS.clb
Part number SW: 045 906 013 E, Hardware part number: 045 906 013 E.
Part number: R3 1.4L EDC G000SG 4271.
Revision: --H03--- Serial number: VWZ7Z0G5933092
Coding: 0003071
Operating number: WSC 49000 143 80495
VCID: 112F82EC0B0893B6E1-513C
Two error codes found:
001027 - Exhaust gas recirculation valve (N18)
P0403 - 000 - Malfunction - Intermittent.
Environmental conditions:
Error status: 00100000
Error priority: 1
Error frequency: 3
Counter: 255
Time: 0.
Speed: 0 RPM.
Speed: 4.0 km/h
Key ratio: 0.0%
Voltage: 13.53 V
Air mass/Flow rate: 0.0 mg/H
Key ratio: 16.0%
Binary value: 00110000
005522 - Signal level sensor / boost pressure sensor.
P1592 - 000 - Implausible relationship - Intermittent.
Error priority: 1
Error frequency: 2
Counter: 255
Mileage: 337,988 km
Time: 0.
Speed: 0 RPM.
Speed: 0.0 km/h
Last: 0.0%
Voltage: 12.46 V
Binary value: 00101100
Pressure: 1091.4 mbar
Pressure: 1101.6 mbar.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics
Label file: DRV\6R0-907-37x-ESP80.lbl
Part number SW: 6Q0 907 379 AS, Hardware: 6Q0 907 379 AS.
Component: ESP 8.0 front panel
Part number: H05 0003
Revision: 00000000 Serial Number: 00000000000000
Coding: 0002365
Operating number: WSC 00046 412 00000
VCID: 0E1599901A368C4EFC-515A
No error codes found.
Address 08: Climate Control/Heating. Label file: DRV\6Q0-820-045.lbl
Part number: 6Q0 820 045.
Component: Air conditioner X0850
VCID: 6ADDF500161E006EC0-515A
Address 09: Central Electronics
Label file: DRV\6Qx-937-049-C.lbl
Part number: 6Q1 937 049 F
Component: 0009 BN-SG. 2S36
Encoding: 09646
VCID: 3E7509503A165CCE4C-5178
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 K
Part number: 19 AIRBAG VW51 0P 0010.
Encoding: 12601
VCID: 2C513318DC6ADE5EF2-515A
Address 17: Control panel module
Label file: DRV\6Q0-920-xxx-17.lbl
Part number: 6Q0 920 825 F
Component: VDO V06 COMBINATION INSTRUMENT.
Coding: 01132
Operating number: WSC 00000
VCID: 377B1C74152C6D868F-5178
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: 01K1 GATEWAY CAN 2S36
Encoding: 00014
VCID: 70E9E76830C2FABE8E-515A
Address 25: Immobilizer
Label file: DRV\5J0-920-xxx-25.clb
Component: VDO V06 IMMOBILIZER.
Coding: 01132
WVWZZZ9NZ8B031810 VWZ7Z0G5933092
Address 44: Steering Assist
Label file: DRV\6Q0-423-156.clb
Part number: 6Q0 423 156 AB
Component: Power Steering Unit - TRW - V270.
Encoding: 10110
VCID: 6FEBE4142DFCE54697-515A
Address 46: Comfort System
Label file: DRV\6Q0-959-433.lbl
Part number: 6Q0 959 433 E
Component: 3F Comfort Device 0002
Coding: 00019
VCID: 3D770E5C371047D655-4B18
Address 76: Parking Assist
Label file: DRV\7H0-919-283.lbl
Part number: 7H0 919 283 A
Component: Parking system 24 KUH 402.
Encoding: 00102
VCID: 30692768F042BABECE-5178
End----------------------------(Duration: 01:53)-----------------------------
Could you give me some advice on what the two errors in the engine control unit (ECU) indicate and what I should check?
Thank you all!
Translated on 22-08-2026, 14:40.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
14-09-2016, 21:41 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Hi.
Okay, the first thing to check is the exhaust gas recirculation (EGR) valve on the intake manifold. You can test its function using an actuator test.
"When there's a fault with the ambient pressure sensor, things get complicated because it's soldered directly onto the engine control unit (ECU). Refer to measurement block 10 for values."
I would obtain a working sensor from a used engine control unit and solder it in place.
Best regards and good luck, Rainer.
Translated on 22-08-2026, 15:02.
Profile PM WWW Garage |
stolley
15-09-2016, 6:42 Subject: Glow Plug Indicator Flashing: Error Code Questions |
dieselschrauber wrote: | Hi
Best regards + success, Rainer |
Hello Rainer,
Thank you very much for the quick response!
I'll test the EGR valve. Regarding the other error, I'll wait and see if it reappears before doing anything.
Volker.
Translated on 22-08-2026, 15:04.
15-09-2016, 8:15 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Quote: | | Regarding the other error, I'm just going to wait and see if it reappears, I think. |
Yes, that's a good choice. As an emergency repair, you could also install two resistors to simulate a specific ambient air pressure. The downside is that driving over high mountain passes will very likely damage the turbocharger and engine. However, if you never actually drive above 1000 meters above sea level in real life, it wouldn't be a problem.
Translated on 22-08-2026, 15:05.
RĂŒdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1513 Karma: +647 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
15-09-2016, 10:43 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Hi there!
I chose this solution for my air fryer: MPX4115A.
It cost me 25 euros for the materials and soldering when I replaced the height sensor. Whether that's also possible for the OP's Polo needs to be checked.
Best regards, RĂŒdi.
Translated on 22-08-2026, 15:07.
Profile PM Garage |
stolley
15-09-2016, 17:01 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Sure, you're welcome!
I simply hope that it was just a temporary thing!
stolley
26-09-2016, 6:19 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Hello!
I have now checked the AGR valve using the actuator diagnosis function.
I only observe that the duty cycle varies between 0 and approximately 25%, depending on the switch position.
Does that mean anything to you?
Translated on 22-08-2026, 15:08.
Hojo-Hörnchen
26-09-2016, 6:26 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Does the brake light switch work, or is a brake light bulb burned out?
Seat Ibiza 6L Cupra TDI.
BUK und GUC. 136.000 Km.
stolley
26-09-2016, 7:06 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Hojo-Hörnchen wrote: | | Does the brake light switch work, or is a brake light defective? |
Um, excuse me?
I think it works! Why? Does that have something to do with it?
Translated on 22-08-2026, 15:09.
Wirus
Joined: 07/11/2016 Posts: 9 Karma: +4 / -0 Location: Aschaffenburg
dieselschrauber likes this. |
26-09-2016, 9:00 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Quote: | Um, excuse me, what did you say?!
It works, I think! Why? Does that have something to do with it? |
Because in some models, the engine warning light comes on when the brake light switch is broken. Don't ask why... probably only the developer of the control unit knows.
I once had this issue with my 2003 Volkswagen Golf Variant TDI. My local mechanic (who, admittedly, is a relative) and has 30 years of experience with VWs, had three questions/comments:
- Geht Dein Bremslicht? No.
- Ist die Bremslichsicherung kaputt? No.
"Then come by, we can replace the brake light switch."
The switch on the brake pedal was actually broken. After replacing it, everything was fine again, and I drove the car for many more years without the problem ever recurring.
Translated on 22-08-2026, 15:10.
26-09-2016, 9:19 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Wirus wrote: | Quote: | Um, excuse me, what did you say?!
The switch on the brake pedal was actually broken. After replacing it, everything was fine again, and I drove the car for many more years without the problem ever recurring. |
That's correct; the errors you reported have nothing to do with this effect.
Translated on 22-08-2026, 15:13.
stolley
26-09-2016, 17:15 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Could you help me determine if the behavior of the AGR (AbgasrĂŒckfĂŒhrung) valve during actuator diagnostics is normal?
Or are there any other tips you might have?
Thank you all!
Translated on 22-08-2026, 15:14.
26-09-2016, 17:25 Subject: Glow Plug Indicator Flashing: Error Code Questions |
Normally, during actuator diagnostics, the duty cycle switches between the minimum and maximum values (fully on/off). If yours is very low, it could be because the EGR valve is simply defective.
Translated on 22-08-2026, 15:15.
stolley
26-09-2016, 19:39 Subject: Glow Plug Indicator Flashing: Error Code Questions |
dieselschrauber wrote: | Normally, during actuator diagnostics, the duty cycle between the minimum and maximum value (fully on/off) changes. If yours is very low, it could be because the EGR valve is simply defective.
Best regards, Rainer |
Okay, thanks for the information, Rainer!
stolley
26-09-2016, 19:42 Subject: Glow Plug Indicator Flashing: Error Code Questions |
dieselschrauber wrote: | Quote: | | Regarding the other error, I'll wait and see if it reappears before doing anything, | .
"Yes, that's a good choice. As an emergency fix, you could also install two resistors to simulate a specific ambient air pressure. The downside is that driving over high mountain passes would very likely damage the turbocharger and engine. However, if you never actually drive above 1000 meters above sea level in real life, it wouldn't be a problem."
This error is actually occurring quite frequently now. It happens repeatedly when the vehicle is stationary! Is there perhaps a way to reset the MSG?
Translated on 22-08-2026, 15:17.
26-09-2016, 19:48 Subject: Glow Plug Indicator Flashing: Error Code Questions |
No, the only option is to repair it.
