Polo diesel with a gasoline transmission???
dieseldusel
Post14-05-2003, 13:26    Subject: Polo diesel with a gasoline transmission??? Quote
I have a diesel gearbox (CEG) from a Polo 3, which is unfortunately difficult to find. Does anyone know if there's an equivalent version for a gasoline engine (possibly the AEB?), and whether it could be used as a replacement?
Thank you.
Translated on 12-07-2026, 14:31.
Post14-05-2003, 13:29    Subject: Polo diesel with a gasoline transmission??? Quote
Look at that: http://www.dieselschrauber.de/Getriebe_Main.html
dieseldusel
Post14-05-2003, 13:33    Subject: Polo diesel with a gasoline transmission??? Quote
I understand that, but it's not explicitly stated that the AEB engine has the same translations/drive axles. It's just not listed as a gasoline engine option... or does that mean it won't work for installation?
Translated on 12-07-2026, 14:32.
Cord
Post19-05-2003, 1:23    Subject: Polo diesel with a gasoline transmission??? Quote
Hi there.
I mean that the right-hand side Gelwave flange is longer on the CEG unit.
"However, it's quite clear; if that's the case, you need to install the flange from the CEG into the AEB and that should do it. Otherwise, everything should fit."
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Doku Polo MJ 2002, Gearbox noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Automatic transmission error. Gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel Exhaust System: Conversion Guide Diesel Engine Technology
No new posts Diesel vs. Gasoline: Which is Best? Transmission, Chassis, Body & Interior
No new posts Hilfe! 1,6 Benziner klingt wie ein Diesel Diesel Engine Technology
No new posts Diesel vs. Gasoline: Which Car is Best? Diesel Engine Technology
