Failure with Bora AJM
racer
Post21-05-2003, 17:45    Subject: Failure with Bora AJM Quote
Hello.
Maybe someone can give me a tip?
I recently had a problem with a Bora model year `99`.
Engine code: AJM.
The engine was turning over normally when starting, but it wouldn't start!
Next, we will replace the power supply relay (109).
No success!
By the way, the control panel was dark, and nothing was working at all!
The fuses in the engine compartment were all fine. Also, no errors could be detected using the diagnostic tool. After about half an hour of troubleshooting, the vehicle started again, and everything was working properly.
Error in the control unit? But why isn't the control panel working???
Thank you in advance, Racer.
kenny
Post21-05-2003, 20:10    Subject: Failure with Bora AJM Quote
Perhaps water leaked in somewhere and caused a short circuit or something similar.
I once had several mysterious electrical problems because water was leaking into the interior through the A-pillar on the passenger side.
VW wanted to replace the comfort control unit's electrical components for about 300 euros, but replacing a door seal also solved the problem icon_wink.gif.
Post21-05-2003, 20:50    Subject: Failure with Bora AJM Quote
Hi.
I think there was no voltage at terminal 15 (ignition). That explains the dead instruments and why the engine wouldn't start.
--> Loose connection in the ignition switch, or along the cable route to the engine control unit/instrument panel, etc.
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L: CD Player Failure Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B: Intermittent GRA Failure Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air conditioner malfunction Transmission, Chassis, Body & Interior
No new posts Fall Detection Display Diesel Engine Technology
No new posts Reverse Camera Replacement Audi A3 8V Electrical Systems, Vehicle Electronics, Multimedia
No new posts Complete loss of comfort features and more in the VW EOS Electrical Systems, Vehicle Electronics, Multimedia
