Fuel System Bleed Passat 1.9 TDI (AVB) 2002
Schmierpfote
Karma: +21 / -0   Thank you, like it!
Post15-01-2017, 18:38    Subject: Fuel System Bleed Passat 1.9 TDI (AVB) 2002 Quote
Hello everyone in the forum, I wanted to bleed the fuel system with VCDS after replacing the tandem pump, but it's not working. Am I doing something wrong, or is it not possible on this old car? I would be grateful for any tips. Best regards, Wolfgang.
Translated on 29-10-2026, 14:07.
Back to top Profile PM Email
Post15-01-2017, 19:07    Subject: Fuel System Bleed Passat 1.9 TDI (AVB) 2002 Quote
Default setting -> Block 035.
If the block is not available, the STG does not offer the function, which unfortunately is the case for some MSTGs. icon_sad.gif
Translated on 29-10-2026, 14:08.
Schmierpfote
Post15-01-2017, 19:30    Subject: Fuel System Bleed Passat 1.9 TDI (AVB) 2002 Quote
Hello Michael, Thanks for the quick reply. I've already tried it that way, but I got a message saying "Control unit not responding" or something similar. Either I'm using VCDS incorrectly, or it doesn't work on the Passat. How many times do I need to turn the ignition on and off until the fuel pre-pump in the tank has purged all the air? The diesel filter is full, but the tandem pump was leaking. Best regards, Wolfgang.
Translated on 29-10-2026, 14:09.
No new posts Fuel system bleeding - Audi A4 3.0 TDI BKN Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 Noises: 8Z0 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wind Noise in Audi A2 (8Z0) 2002: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Opel Movano Fuel System Bleed: G9T Engine (2002) Diesel Engine Technology
No new posts Emergency Start 1.9 TDI MBK AVF VW Passat 3BG On-Board Diagnostics (OBD)
No new posts Passat TDI 2002: Euro 3 Specs & Info Diesel Engine Technology
No new posts OT marking on a 3BG Passat 1.9TDI AVF with TT5 automatic ... Diesel Engine Technology
