PDE Injector Replacement: 03G130073G
audi94
Post12-02-2017, 17:00    Subject: PDE Injector Replacement: 03G130073G Quote
Hello Dieseli fans,
For the aforementioned PD element, the nozzle insert needs to be replaced.
What should one pay attention to, or what is the "trick 17" for using the nozzle insert without...?
To be able to switch damage types.
PS: (Repair kit photo is attached - BKD engine, 103 kW, Skoda Octavia II, TDI, 2.0L).
I would be grateful for any tips and tricks you can offer.
Best regards - Audi94
 File size:  16.97 KB
 Viewed:  987 times
 File size:  25.04 KB
 Viewed:  554 times
Translated on 18-10-2026, 8:09.
Post13-02-2017, 9:45    Subject: PDE Injector Replacement: 03G130073G Quote
Okay, please provide the German text you would like me to translate into English.
Ich kann den Inhalt dieser URL nicht abrufen, da ich keinen Zugriff auf externe Websites habe. Bitte gib mir den Text, den du übersetzt haben möchtest.
The cap nut should not be opened with a pipe wrench, but rather with a suitable wrench or the part shown in the picture. Details about the part can be found in the video.
Translated on 18-10-2026, 8:10.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Düseneinsatz <VW TDI vs. BMW TDS> Diesel Engine Technology
No new posts Starting problems with 1.9 TDI after injector replacement Diesel Engine Technology
No new posts Switch LMM: How to Change Your LMM Diesel Engine Technology
No new posts Replace Door Seal: DIY Guide & Tips Transmission, Chassis, Body & Interior
