Webasto Heater Remote Control: Retrofit Guide
dr.zikzak
Post07-02-2017, 17:17    Subject: Webasto Heater Remote Control: Retrofit Guide Quote
Hello everyone in the forum!
I have a Golf IV (built in May 2002) with a 1.9 TDI ARL engine that I use as my winter car, and it already has a Webasto auxiliary heater installed by the original owner.
This one works perfectly, however, so far I can only start it using the built-in clock (Type 1533, oval), which is a problem. I work in a hospital, and it's often not possible to plan exactly when you will be able to leave, down to the minute...
Therefore, it would be worth considering retrofitting a remote control, or even better, enabling control via an app.
Okay, here are my problems/questions:
Unfortunately, I can't say exactly what type of heating system is installed in my car, but I'm sure it's older than 8 years.
Furthermore, I already have a diagnostic adapter, and I thought I could use it to determine the model designation... but so far, I haven't been successful; I can't find a clear naming convention. Communication with the control unit works when I select the device type "Thermo Top C, E, Commercial, P, C/Z MB/DC"...
Can I upgrade any heating system, or is it only possible with certain models or production years?
Is there a way to determine this without disassembling the vehicle or removing the bumper?
Thank you very much, and best regards.
Translated on 21-10-2026, 22:02.
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Remote control for stand heater (Golf V) - programming On-Board Diagnostics (OBD)
No new posts Webasto DW 50: Parking Heater Installation & Guide Transmission, Chassis, Body & Interior
No new posts Webasto auxiliary heater for 2.5 TDI AEL/AAT models with ... Transmission, Chassis, Body & Interior
No new posts Webasto Heater Diagnosis: Troubleshooting Guide Diesel Engine Technology
