Opel Movano Water Pump: G9T Engine, 2002 Model
jörg schmidt
Karma: +21 / -0   Thank you, like it!
Post05-03-2017, 10:30    Subject: Opel Movano Water Pump: G9T Engine, 2002 Model Quote
Hello everyone,
I hope there are some people here who know about Opel cars.
Question: For the aforementioned engine model (2.2L diesel, 90 HP), does the timing belt need to be removed as well when replacing the water pump?
Jörg
Seat Ibiza 6L Sport ASZ EZ Mai 2003
>468000km -schweren Herzens verkauft
Seat Ibiza 6J FR CFHD EZ Mai 2015
>178000km
Fiat Ducato Kasten 2.3 Multijet
EZ 3.2011 >230000km
Translated on 25-08-2026, 4:27.
Post05-03-2017, 11:11    Subject: Opel Movano Water Pump: G9T Engine, 2002 Model Quote
I have no idea... but if the timing belt drives the water pump, that's the consequence. However, you can easily check this yourself by taking a closer look under the hood.
jörg schmidt likes this.
Post05-03-2017, 11:21    Subject: Opel Movano Water Pump: G9T Engine, 2002 Model Quote
The timing belt doesn't need to be removed.
P.S. Don't forget to change the oil; it's unavoidable that a significant amount of coolant will leak into the oil pan.
Translated on 25-08-2026, 4:28.
jörg schmidt
Post05-03-2017, 11:48    Subject: Opel Movano Water Pump: G9T Engine, 2002 Model Quote
o.k. Thank you.
I did some online research, and in a Renault forum, someone mentioned that the water pump needs to be removed as well.
I've taken it apart now. The water pump is located under a separate cover.
I'm actually just doing the timing belt replacement. As a result of this thread, I'll leave the old water pump where it is.
By the way, this is my first time replacing a water pump icon_wink.gif. Please keep your fingers crossed for me that I don't mess anything up }.
If I have any more questions, I'll post them here as well.
Sure, you're welcome!
Jörg
>178000km
EZ 3.2011 >230000km
Translated on 25-08-2026, 4:29.
jörg schmidt
Post05-03-2017, 13:01    Subject: Opel Movano Water Pump: G9T Engine, 2002 Model Quote
I can't find the hole where the crankshaft dowel pin goes in.
It should be located somewhere above or behind the oil filter, and a screw should be positioned in front of it icon_question.gif.
Edit:
I think I've found it. It must be the screw where the oil filter is attached. You can see it in a YouTube video.
>178000km
EZ 3.2011 >230000km
Translated on 25-08-2026, 4:31.
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 Noises: 8Z0 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Opel Movano: DIY Diagnostic System (G9T, 2002) Diesel Engine Technology
No new posts Opel Movano BJ 2002 MKB G9T Kraftstoffsystem entlüften Diesel Engine Technology
No new posts Opel Movano EGR Valve: Disable Test (2002) Diesel Engine Technology
No new posts Water Pump Replacement 1Z Diesel Engine Technology
