Good evening.
I need instructions (a normal reset procedure does not work on this car) for a COMPLETE reset on a Golf 7.
Background: I had the oil changed about 4 weeks ago, and I also reset the service indicator. Now it's displaying "Inspection due in xx days."
Thank you for your help, and best regards.
Alevuz.
Tuesday, February 14, 2017, 11:40:57:53341
VCDS, a VAG/VAS emulator based on Windows, runs on Windows 10 x86.
VCDS Version: RKS 17.1.2.0
Data as of: 20170131 DS267.1
Vehicle Identification Number: WVWZZZAUZFP085531
License Plate: GOLF 7 - ROLAND
Mileage: 49229 km
Repair order: G7-Roland
The company announced record profits for the quarter.
Vehicle type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
Mileage: 49,229 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: Error 0010.
08-Climate/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000.
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
42-Door electric driver -- Status: OK 0000
44-Steering assist -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
5F-Information Selection. I -- Status: Error 0010.
Address 01: Engine Control (2D2D2-CXXB) Label file: DRV\04L-907-309-V1.clb
Part number SW: 04L 906 056, hardware number: 04L 907 445 B.
Part: R4 1.6L TDI H06 8983
Revision: 22004001
Encoding: 01114032430401092000
Operating number: WSC 00028 028 00073.
ASAM Dataset: EV_ECM16TDI03004L906056 002009
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 6ADE67C18DAFB4115D-803E
No error codes found.
Readiness: Not Available.
Address 03: Brake Electronics (J104)
Label file: 5Q0-907-379-IPB-V1.clb
Part number SW: 3Q0 907 379 Q, Part number HW: 3Q0 907 379 F.
Component: ESC H42 0610.
Revision: 00000000 Serial number: 60495000002758
Encoding: 01FA62A124280971077C060341C42580462490E06082A4F30040F07AC002
Operating number: WSC 00028 028 00067.
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036.
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 489AFD49F363A6016B-801C
"One error found:"
16401 - Tire pressure warning.
C102D 00 [008] - -
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2.
Error frequency: 1.
Lost Count: 76
Mileage: 39,454 km
Date: 2016.10.23
Time: 12:14:37
Address: 08: Climate Control/Heating (J255)
Label file: 5G0-907-044.clb
Part number SW: 5G0 907 044 BD, Hardware: 5G0 907 044 BD.
Part: Climatronic H03 1001.
Revision: 00001K08
Encoding: 00020104202100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
Control unit for the fresh air blower (front).
Refrigerant pressure and refrigerant temperature sensors:
Air quality sensor:
"One error found:"
1048835 - Function limitation due to engine control unit.
P1719 00 [008] - -
Error priority: 6.
Error frequency: 1.
Lost Count: 169
Mileage: 49,171 km
Date: 2017.02.14
Time: 08:07:04
Voltage at terminal 30: 13.5 V.
Auxiliary heating: multi-stage activation for heating operation: activation at level 3.
Auxiliary heating: stepped, setpoint value: 3.
Auxiliary heating: setpoint level: 3.
Auxiliary heating: Setpoint value of the control system: 3.
Address 09: Central Electronics (J519)
Label file: 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 084 AJ, HW: 5Q0 937 084 AJ.
Component: BCM MQBAB H H18 0137.
Serial number: 01011504302968
Encoding: 00000846C24102FB4BE44000001C07081000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 000A25699BD35E41E3-8054
Wiper motor control unit:
Subsystem 1 - Part number SW: 5G1 955 119 A HW: 5G1 955 119 A Label file: DRV\5QX-955-119-V1.CLB
Part number: WWS 150206 043 0551.
Serial number: 150211075636
Encoding: 0E4DDD
Rain and light sensor:
Subsystem 2 - Part number SW: 5Q0 955 547 A HW: 5Q0 955 547 A Label file: DRV\5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M02D20H11M40S45
Encoding: 00A8DD
Address 10: Parking Assist 2 (J791)
Label file: 5Q0-919-298.clb
Part number SW: 5Q0 919 298 F, hardware number: 5Q0 919 298 F.
Part: PARKING ASSIST PLA H12 0047
Revision: -------- Serial number: 39431503803451
Encoding: 0031061041
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 428EEF61D55F8C51B5-8016
Address 15: Airbag (J234)
Label file: DRV\5Q0-959-655.clb
Part number SW: 5Q0 959 655 D, Hardware: 5Q0 959 655 D.
Part: Airbag VW20 014 0385
Serial number: 003F6R0G8W2N
Encoding: 98CCC000000000005C0000CF004800000065
Operating number: WSC 00028 028 00061.
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 418CE06DD0599749AC-8014
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 480 001 202 15
Component: SideSensor_Df 001 0887
Serial number: 35767000000C0539231K
Encoding: 2D2D2D
Crash sensor for the side airbag, passenger side:
Subsystem 2 - Part number: SW: ----------- HW: 480 001 202 15
Component: SideSensor_Pf 001 0887
Serial number: 35867000000DBAF82316
Encoding: 2D2D2D
Crash sensor for rear side airbag, driver's side.
Subsystem 3 - Part number: SW: ----------- HW: 480 401 202 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502C7198E154F16J
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 480 401 202 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502C7198E1553226.
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: ----------- HW: 480 400 502 15
Component: FrontSensor_D 001 6149
Serial number: 3556502AB196FF5290D.
Encoding: 2D2D2D
Address 16: Steering Wheel Electronics (J527)
Label file: DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 507 AB, Part number HW: 5Q0 953 549.
Bauteil: Lenks. Module 007 0070.
Revision: -------- Serial number: 18021504400166
Encoding: 0600
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 76E643B1C91760F1C9-8022
Address 17: Terminal block (J285) Label file: DRV\5G0-920-XXX-17.clb
Part number SW: 5G1 920 751, hardware: 5G1 920 751.
Part number: KOMBI 304 4270.
Encoding: 07A41A002390000800086A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009037
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 65C414FD64B19B6970-8030
Address 19: Diagnostic interface (J533)
Label file: DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 AA, hardware: 5Q0 907 530 K.
Part: GW MQB Low 210 2203
Revision: -------- Serial number: 21121410801107
Encoding: 030000040F087300EF000248080F00010001050000000000000000000000
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_011.rod
VCID: 70EA75A9AB734EC113-8024
Generator:
Battery monitoring control unit:
Subsystem 2 - Part number SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Part number: J367-BDM, Hella H04 8050.
Serial number: 3430525603
Address 42: Door electric strike (J386) Label file: 5QX-959-X93-42.clb
Part number SW: 5Q4 959 593 C, hardware number: 5Q4 959 593 B.
Component: TSG FS 009 0015
Serial number: 0000137155667
Encoding: 00310320D000020000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4584F47DC471BB6990-8010
Rear door control module, driver's side.
Subsystem 1 - Part number SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Part: Rear panel FHSG DRV 007 0002.
Serial number: 00000000000007936075.
Encoding: 010000
Address 44: Steering Assist (J500)
Label file: DRV\5Q0-909-144.clb
Part number SW: 5Q0 909 144 R, Hardware number: 5Q0 909 144 R.
Part number: EPS_MQB_ZFLS 126 1061.
Encoding: 0302
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 4380EA65CA458559BE-8016
Address 52: Power door lock, front passenger side (J387). Label file: 5QX-959-X92-52.clb.
Part number SW: 5Q4 959 592 C, hardware number: 5Q4 959 592 B.
Component: TSG BFS 009 0015
Serial number: 0000136877917
Encoding: 00310120DE00020000801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 4482E979CF4B826187-8010
Door control module, rear passenger side:
Subsystem 1 - Part number SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Component: Rear panel FHSG PSG 007 0002.
Serial number: 00000000000008008755.
Encoding: 090000
Address 5F: Information selection. I (J794)
Label file: 5G0-035-MIB-STD1.clb
Part number SW: 5G0 035 846 A, hardware number: 5G0 035 846 A.
Component: MU-S-N-ER 041 0430
Serial number: V1F01602152788
Encoding: 02730001FF00000011110001000800031F0100840100010045
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 27585EF55E3D497982-8072
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9RS406QW1
Storage media:
Subsystem 2 - Part number SW: 5G0 919 866 Q HW: -----------
Component: ECE 2015 --- 0045
Serial number: --------------------
"One error found:"
6145 - Display and control unit 1 for information electronics.
B129E 07 [009] - Mechanical fault.
Error priority: 6.
Error frequency: 1.
Lost Count: 181
Mileage: 43,432 km
Date: 2016.12.13
Time: 07:09:43
Voltage at terminal 30: 14.1 V.
End----------------------------(Duration: 03:44)-----------------------------
