Steering column lock inaccessible
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
micc
Post21-04-2017, 21:47    Subject: Steering column lock inaccessible Quote
Hello and thank you for the many interesting contributions in the forum.
I have been following this forum as a reader for quite some time.
Now I would like to ask a question and hope that is okay. If I am doing something wrong, please excuse me.
For the past few days, the yellow and sometimes the red steering wheel symbol has occasionally appeared on my Passat B6 TDI, manufactured in 2010. After turning off the ignition, the message "Steering Lock - Workshop" appears. After searching in several forums, I believe it could be the known issue with the steering column control unit.
However, when scanning with VCDS, the steering column control unit is not accessible.
"The message "Address 2B Steering Lock Unreachable" appears.
Is there a way to still read the actual error message?
Post21-04-2017, 22:33    Subject: Steering column lock inaccessible Quote
Bad, if the fuses and cables/connections are okay, it doesn't look good.
Best regards, Rainer
micc
Post22-04-2017, 7:14    Subject: How bad is it? Quote
Thank you for the response. Is it the case that - since the control unit is unreadable and therefore a new one cannot be programmed - I can only have a replacement (and repair) carried out by VW? I had previously hoped that replacing the microswitches would fix the problem, or at most, replacing the steering column control unit.
Unfortunately, for example, the headlight leveling control unit is also unresponsive, even though the headlight adjustment function works. Is the defect in this case attributable to a higher-level control component?
Unfortunately, I can't find the corresponding Autoscan from VCDS on my computer. However, I have saved the data in a Word document.
Post22-04-2017, 9:52    Subject: Steering column lock inaccessible Quote
Please perform a fresh scan, and before doing so, please clear all error codes (Round message to all control units in the VCDS Auto Scan dialog, left center).
micc
Post22-04-2017, 10:59    Subject: Steering column lock inaccessible Quote
Thank you, here is the scan ...
micc
Post24-04-2017, 8:02    Subject: Upload Scan Quote
Sorry, it seems the first scan upload was not received.
Log-24042017-WVWZZZ3CZAE204178-197650km.txt
 File name:  Log-24042017-WVWZZZ3CZAE204178-197650km.txt
 File size:  13.65 KB
 Downloaded:  509 times
micc
dieselschrauber likes this.
Post24-04-2017, 21:37    Subject: No match found. Quote
After I had checked the fuses in the dashboard and engine compartment again, I was unfortunately still unable to determine the cause. Also, the connector on the steering column control unit is clearly stuck.
After the major issue with the flashing steering wheel occurred during Easter, I had temporarily removed the check for ELV from the specification list and then put it back in. Unfortunately, I don't know if the inoperability of the tax device has been ongoing since this point in time.
What data is required for the commissioning of a new control device?
Can this be obtained from the data of an older scan where the control unit was still accessible?
Post25-04-2017, 8:52    Subject: Steering column lock inaccessible Quote
Can they be obtained from the data of an older scan where the control unit was still accessible?
Probably yes, if the new tax device has the same VAG part number.
Post25-04-2017, 9:01    Subject: Steering column lock inaccessible Quote
Is the steering column STG not part of the WFS in the 3C?
I thought there were things like comfort control, engine control, and the central locking system in there. But I must admit, I am not entirely sure.
Greetings
Guste
Post25-04-2017, 9:14    Subject: Steering column lock inaccessible Quote
Greetings
Gute
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A7 4K: Control units unreachable & data bus errors On-Board Diagnostics (OBD)
No new posts Control Unit 46: Suddenly Unreachable? On-Board Diagnostics (OBD)
No new posts HEX-NET Firmware update Server not reachable On-Board Diagnostics (OBD)
No new posts VCDS / Address 37: Navigation not accessible Electrical Systems, Vehicle Electronics, Multimedia
