Hello everyone,
Currently, I have a Q5 where the rearview camera stopped working after a navigation system update.
The rear-view camera was installed approximately 2 years ago, and a navigation system update was installed last week. Since then, the rear-view camera has not been working.
Today, I tried to code it so that it would work again, but unfortunately, with limited success.
The control unit for the rear-view camera is being recognized again, but unfortunately, no image is displayed when the reverse gear is engaged. In addition, the optical parking assist feature is missing from the MMI screen.
According to VCDS, the camera is not successfully calibrated, but this shouldn't affect the issue of the missing image.
Does anyone have any other ideas on how to get this working again?
I'm attaching the
Autoscan file.
Thank you very much.
Thilo
VCDS version: RKS 15.7.4 runs on Windows XP x86.
Data as of: 20160226
Wednesday, April 5, 2017, 3:28:10:58542.
Vehicle type: 8R (8R0)
Scan: 01 02 03 05 07 08 09 15 16 17 19 20 3C 42 44 46 52 53 56 5F
62 69 6C 72 AC
Vehicle Identification Number: WAUZZZ8R4DAXXXXXX Mileage: 98180 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
07-Control Unit/Interface -- Status: unreachable 1100
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnostic interface -- Status: Error 0010.
20-High Beam Assist -- Status: OK 0000
3C track switch -- Status: OK 0000.
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000.
53-Parking brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Selection. I -- Status: Error 0010
62- Door, electric, left and right -- Status: OK 0000.
69 followers -- Status: OK 0000
6C Reverse Camera -- Status: Error 0010.
72-Door, electric, high, right side -- Status: OK 0000.
AC reducing agent dosage. -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-CGLC)
Label file: DRV\03L-906-018-CGL.clb
Part number SW: 03L 906 018 JN, HW: 03L 906 018 JL.
Part: R4 2.0l TDI H25 9978
Revision: 45H25---
Encoding: 2A254012243601080000
Operating number: WSC 41752 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018JN 003006
ROD: EV_ECM20TDI01103L906018JN.rod
VCID: 7F0B35D4E619D2C607-802A
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission (J217)
Label file: DRV\0B5-927-156.clb
Part number SW: 8R1 927 156 P, HW: 0B5 927 156 J.
Part number: 0B5 20 TDIRdW H01 0002
Revision: --H01--- Serial Number: 0000000205
Encoding: 000001
Operating number: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501021 001009
ROD: EV_TCMDL501021.rod
VCID: 499F6B0CE85DAC76E9-801C
Address 03: Brake Electronics (J104)
Label file: DRV\8R0-907-379-V1.clb
Part number SW: 8R0 907 379 P, HW: 8R0 907 379 P.
Component: ESP8 quattro H09 0080
Revision: -------- Serial Number: --------------
Encoding: 219D4C
Operating number: WSC 76783 150 104287
VCID: 4D975F1C1435B056C5-8018
Address 05: Access/Startup Authorization (J393)
Label file: DRV\8K0-907-064-05.clb
Part number SW: 8K0 907 064 GH, HW: 8K0 907 064 FH.
Component: BCM2 2.0 H11 0621
Revision: 00002001
Encoding: 05A54040000000000000
VCID: 7CF1C2D8FF0FC9DE22-8028
Subsystem 1 - Part number SW: 8K0 959 754 D, HW: 8K0 959 754 D.
Part number: FBSAUDIB8 IDG H71 0083.
Address 07: Number of/Control units.
unavailable
Address 08: Climate Control/Heating (J255)
Label file: DRV\8Kx-820-043-3Z.clb
Part number SW: 8K1 820 043 AJ, Hardware number: 8K1 820 043 AJ.
Component: CLIMATE CONTROL, 3 ZONES, H04, 0123.
Revision: C1000000 Serial Number: 01300720120238
Encoding: 342102E080
VCID: 70E9E6E8A347BDBE8E-8024
Address 09: Central Electronics (J519)
Label file: DRV\8K0-907-063.clb
Part number SW: 8K0 907 063 DH Hardware number: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial Number: 00000458774902
Encoding: 260000108074AFE00181408300001D0D0F9CE70826090201000008004401030100000024000000
Operating number: WSC 04899 003 1048576
VCID: 78F9DEC8CB37E5FE46-802C
Subsystem 1 - Part number SW: 8R1 955 119 A, HW: 8R1 955 119, Label file: DRV\1KX-955-119.CLB.
Part number: WWS416 120717 H11 0050.
Encoding: 01DD13
Subsystem 2 - Part number SW: 8U0 955 559 B HW: 8U0 955 559 B Label file: DRV\8U0-955-559.CLB
Part number: G397_RLFS H06 0002
Encoding: 02005C
Subsystem 3 - Part number SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part number SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Address 15: Airbag (J234) Label file: DRV\8R0-959-655.clb
Part number SW: 8R0 959 655 G, Hardware number: 8R0 959 655 G.
Part: Airbag
VW-AU10 H45 0610
Serial number: 003JPD91HN6U
Encoding: 30463431313030303030554A304C38523053
ASAM Dataset: EV_AirbaAU10SMEAU416 002004
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48996E08F357557EF6-801C
Crash sensor for driver-side side airbag:
Serial number: 6334MSME6F652E1AW
Crash sensor for side airbag, passenger side:
Serial number: 6344MSME6E037809L
Rear side airbag crash sensor (driver's side):
Serial number: 6352QSME191C4D48T
Crash sensor for rear side airbag, passenger side:
Serial number: 6362QSME2D172676M
Crash sensor for front airbag, driver's side:
Serial number: 63732SME1E171960.
Crash sensor for front airbag, passenger side:
Serial number: 63832SME1A1A095A3
Address 16: Steering Wheel Electronics (J527)
Label file: DRV\8K0-953-568.clb
Part number SW: 8K0 953 568 L, Hardware number: 8K0 953 568 L.
Component: Steering module. Part number: H03 0004.
Revision: -------- Serial Number: 90372LGN000MY
Encoding: 000037
VCID: 43837924C271762623-8016
Component: E221 - MFL H03 0003
Address 17: Control panel module (J285)
Label file: DRV\8R0-920-xxx-17.clb
Part number SW: 8R0 920 930 P, Hardware number: 8R0 920 930 P.
Component: COMBINATION INSTRUMENT. H35 0553
Revision: 00000000 Serial Number: RF7579L7D
Encoding: 13A6220003010008000000
VCID: 418F732CD86D643631-8014
Address 19: Diagnostic interface (J533)
Label file: DRV\8T0-907-468.clb
Part number SW: 8R0 907 468 J, HW: 8R0 907 468 D.
Component: GW-BEM 5CAN-M H11 0051
Revision: 1Z090025 Serial Number: 2541Z12717013B
Encoding: 80CF07FF00
VCID: 46856030F143430E04-8012
Subsystem 1 - Part number SW: 8R0 915 181, HW: 8R0 915 181.
Part number: J367-BDM H07 0141.
Subsystem 2 - Part number SW: 8K0 959 663, HW: 8K0 959 663.
Component: J532_DCDCStab H17 0042
"1 error found:"
00459 - Control unit; display and operating unit for information; front (J523)
004 - No signal/communication.
Environmental conditions:
Error status: 01100100
Error priority: 2
Error frequency: 1
Lost Count: 9
Mileage: 98,179 km
Time: 0
Date: 2017.04.05
Time: 11:34:24
Binary value: 01111
Voltage: 14.70 V
Quantity: 6
Binary value: 10000
Address 20: High Beam Assist (J844)
Label file: DRV\8K0-857-511.clb
Part number SW: 8T0 857 511 AD, HW: 8T0 857 511 AD.
Component: FLA H04 0012
Revision: AA001002
Encoding: 02012064747464545425363E00
Address 3C: Lane Change (J769)
Label file: DRV\5Q0-907-566.clb
Part number SW: 8T0 907 566 A, HW: 8T0 907 566.
Component: SWA Master H17 0040
Serial number: 0180777931.
Encoding: 010321
ASAM Dataset: EV_LaneChangeAssist 001020
ROD: EV_LaneChangeAssist_AU21.rod
VCID: 3E7508D0A1931BCE4C-806A
Control unit 2 for lane change assist:
Address 42: Door electronics. Driver (J386) Label file: 8K0-959-793.clb
Part number SW: 8K0 959 793 R, HW: 8K0 959 793 P.
Part: TSG FA H02 0506
Revision: Serial number: 0000035939523
Encoding: 011D12204000440004
VCID: 4FAB45141E398246B7-801A
Address 44: Steering Assist (J500)
Label file: DRV\8K0-909-144.clb
Part number SW: 8R0 909 144 F, HW: 8R0 909 144 B.
Component: RCEPS H37 0507
Revision: 00001000 Serial Number: 0027753715
Encoding: 100000010001
Operating number: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
FILE: EV_RCEPSAU48X.rod
VCID: 3B7301C4B2810EE66B-806E
Address 46: Comfort System (J393)
Label file: DRV\8K0-907-064-46.clb
Revision: 00002001 Serial number: 0180219770
Encoding: 01000E2020B90001852005368004000F
Address 52: Door opener (or electric door release). Front passenger airbag. (J387) Label file: 8K0-959-792.clb
Part number SW: 8K0 959 792 R, HW: 8K0 959 792 P.
Component: TSG BF H02 0506
Revision: Serial number: 0000035844126
VCID: 4E95581019338B4EBC-801A
Address 53: Parking brake (----)
Label file: DRV\8K0-907-801-V2.clb
Part number SW: 8K0 907 801 L, HW: 8K0 907 801 J.
Component: EPB-4 H01 0003
Revision: -------- Serial Number: 20000000126881
ASAM Dataset: EV_ParkBrake 001027
ROD: EV_ParkiBrake_AU48.rod
VCID: 38791EC883B725FE86-806C
Address 56: Radio (R) Label file: DRV\4F0-035-0xx-56.clb
Part number SW: 4G0 035 056 E, HW: 4G0 035 056.
Part: Radio U STD H60 0093.
Revision: AB001007 Serial number: 230GR0C2582433
Encoding: 010003020100000001
VCID: 2343D9A42231562643-8076
Address 5F: Information selection. I (J794) Label file: DRV\4E0-035-6xx-5F.clb
Part number SW: 8R1 035 670 C, HW: 8R1 035 670 C.
Part: H-BNT-EU H44 0524
Revision: -------- Serial Number: 207HY0C7511384
Encoding: 160100060005A1EF1580AB5E00000403040000000000000000
VCID: 336329E492D1C6A6B3-8066
Subsystem 1 - Part number: 8R0 060 884 ED
Part number: EUR 2017 2402.
Subsystem 2 - Part number SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104.
Subsystem 3 - Part number SW: 8T0 919 611 C HW: 8T0 919 611 C
Component: E0380, Used. Part number: H02 0020.
Subsystem 4 - Part number: 8R0 060 961 C.
Component: CD Database 3638
"1 error found:"
03276 - Verify software version management.
text
000 - -
Error status: 01100000
Error priority: 6
Error frequency: 1
Lost Count: 9
Mileage: 98,179 km
Time: 0
Date: 2017.04.05
Time: 11:34:44
DUA130, Front, Male, 0, 0, 6
Address 62: Door electric, high, left (J388)) Label file: 8K0-959-795.clb
Part number SW: 8K0 959 795 D, Part number HW: 8K0 959 795 D.
Component: TSG HL H01 0506
Revision: Serial number: 0000035876540
Encoding: 010C12204000240004
Address 69: Trailer (J345) Label file: DRV\8K0-907-383.clb
Part number SW: 8K0 907 383 D, Part number HW: 8K0 907 383 D.
Part: Trailer H09 0100
Revision: 1G001001 Serial Number: 00000178344058
Encoding: 0109080000000000
Operating Number: WSC 00000 000 00000
VCID: 356717FC9CA5D8969D-8060
Address 6C: Reverse camera
Label file: DRV\8T0-907-441.clb
Part number SW: 8R0 907 441 A, HW: 4L0 907 441 B.
Part: J772__Rearview 0040
Revision: --H07--- Serial Number: 525PA8-J29A2Y2
Encoding: 1030010
Operating number: WSC 60749 001 1048576
VCID: 34612AF857DFC19EAA-8060
"1 error found:"
03006 - Reverse camera system not calibrated.
text
000 - -
Error priority: 2
Error frequency: 1
Lost Count: 10
Time: 0
Address 72: Door electric, high, right (J389) Label file: 8K0-959-795.clb
Part: TSG HR H01 0506
Revision: Serial number: 0000035872603
Address AC: Reducing agent dosing unit. (J880)
Label file: 4G0-907-355.clb
Part number SW: 4G0 907 355 C, HW: 4G0 907 355 B.
Component: SCR Control Unit G2 H09 0010
Revision: 00000000 Serial number: 121870145
ASAM Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100.rod
VCID: 2B53318442E19E66FB-807E
End----------------------------(Duration: 04:11)-----------------------------
