Billiboy
Joined: 05/15/2017 Posts: 2 Karma: +1 / -0 Location: Berlin
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
22-05-2017, 16:05 Subject: Octavia 1Z Auxiliary Heater Removal |
Is it not possible to detach the actuator rod or remove the servo motor?
Translated on 25-08-2026, 17:38.
Profile PM Garage |
Billiboy
dieselschrauber likes this. |
22-05-2017, 20:48 Subject: Octavia 1Z Auxiliary Heater Removal |
Okay, here's the translation:
"I will figure it out myself."
It's best to adjust the temperature of the heater on the driver's side before disconnecting the auxiliary heater. This will cause the actuator motor to rotate, making the screw accessible. Then, you can easily pull the part out.
matthiasTDI96 Profi-Schrauber
23-05-2017, 0:10 Subject: Octavia 1Z Auxiliary Heater Removal |
A service position with VCDS would likely also be beneficial.
Translated on 25-08-2026, 17:39.
