After the oil level sensor also indicated a defect, the following was discovered: cable damage caused by rodent chewing.
The solenoid valve for the EGR cooling system is located at the front of the engine, on the right-hand side above the throttle valve.
To disassemble the pins in the connector, follow these steps:
- It's best to completely disconnect the plug, as the very short cable could otherwise cause a seizure. Before doing so, make sure to remember which cable was connected to which pin on the plug.
- Remove the pink retaining clip from the connector using a flat-head screwdriver.
- Use a wire or a small Allen wrench to remove the sealing ring.
- Bend a paperclip into a U-shape and insert it from the front, outside, next to the contact pin.
- Using a wire, push the contact pin and seal backwards out of the connector housing from the center. Some forward and backward movement and fiddling was necessary for me; the paperclip had difficulty releasing the connector pin from the housing. There is also proper tool available for this, but it's questionable whether it's worth buying just for your own vehicle.
- Pry apart the metal casing at the back of the connector pin and slide the seal backwards.
- Cut off the old cable, solder the new cable in place, reinsert the seal, bend the metal casing back together, and reassemble everything.
