I just disassembled the control panel in my T5 to replace the actuator motor V159 (and while I'm at it, I'm also installing a reverse camera!).
My question to you now is:
I wanted to test the new actuator or perform the initial setup before assembly. However, when I connect VCDS and select the corresponding control unit, it doesn't respond. Could this be due to all the disassemblies?
