Ross Tech V2 NET: Won't Stay in Slot?
alexandererlangen
Post24-06-2017, 14:21    Subject: Ross Tech V2 NET: Won't Stay in Slot? Quote
I've only recently started using the VCDS device. However, it doesn't seem to fit very securely in the vehicle and appears to be slipping out over time.
I've now noticed that in the 2-pin configuration, one pin has two middle pins that are significantly longer than the rest.
Is it the same for you?
Schöne Grüße
Alexander
Translated on 25-09-2026, 1:12.
chli1976
Post24-06-2017, 19:25    Subject: Ross Tech V2 NET: Won't Stay in Slot? Quote
Yes, that's normal.
VCDS
Translated on 25-09-2026, 1:13.
Post25-06-2017, 15:54    Subject: Ross Tech V2 NET: Won't Stay in Slot? Quote
The two middle, longer pins are for vehicle ground and signal ground. It is intentional that these two pins connect to the vehicle first when plugged in.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ross-Tech USB interface not found! On-Board Diagnostics (OBD)
No new posts HEX-NET: Reset to factory settings On-Board Diagnostics (OBD)
No new posts Which Ross-Tech diagnostic interface? On-Board Diagnostics (OBD)
No new posts Ross-Tech 9082 with DS-Hex Interface? On-Board Diagnostics (OBD)
