I need the values for the position sensor of the vacuum manifold for a BMR TDI 2.0.
Here are the values I need:
Control Unit 01
Measurement blocks 043 (voltage values)
Without running the motor
Valve N75 in the closed position. All hoses are connected normally.
Vacuum chamber, hose disconnected, idle. N75 Does not create a vacuum in the container (VTG rod in contact at the bottom)
Vacuum chamber, tube directly connected to vacuum (Vtg bar is at its maximum position)
Thank you for your efforts.
Jürgen
