Exchange-MSG blocked P1570
amishorty
Karma: +9 / -1   Thank you, like it!
2004 Volkswagen Passat
Post10-08-2017, 18:29    Subject: Exchange-MSG blocked P1570 Quote
Hello community,
{DATA}
Polo 6X 1.0 MPI Engine Code AUC, Year 2001
How do I unlock an AT-MSG again?
Al had probably a faulty solder joint.
Does anyone have any advice?
I have the data from VCDS.
Starts briefly and then stops.
In the WFS, there is nothing.
Help would be appreciated.
Michi
Karma: +805 / -0   Thank you, like it!
Post10-08-2017, 22:43    Subject: Exchange-MSG blocked P1570 Quote
Autoscan?
Best regards, Rainer
amishorty
Post11-08-2017, 9:21    Subject: Exchange-MSG blocked P1570 Quote
Hi Rainer,
danke, aber hab ich schon hin bekommen.
Michi
vag-driver
dieselschrauber likes this.
Post11-08-2017, 10:29    Subject: Exchange-MSG blocked P1570 Quote
That would be great - for the documentation, to describe how you fixed the error.
Andreas
amishorty
Post11-08-2017, 17:56    Subject: Exchange-MSG blocked P1570 Quote
@ Andreas
WFS was to blame, even though there was no entry.
WFS upgraded, the smaller of the two connectors was disconnected and reconnected multiple times, done. DO NOT USE CONTACT SPRAY!!!!!!!! WFS reinstalled.
Original MSG reinstalled, car scan performed, WFS called up, keys deleted and re-programmed, VCDS program closed, ignition off and on, VCDS started, MSG called up, engine started..........and it ran.
No more errors, neither in the MSG nor in the WFS.
Motor run for 10 minutes, turned off, and restarted several times in a row.
No more errors detected.
Hoping that this will also remain as is.
The WFS is very susceptible to interference due to contact problems with the WFS. Although it is securely screwed behind the dashboard, I believe the error messages are caused by vibrations over a long period.
However, there is not much that can be done.
Absolutely, DO NOT use contact spray on control equipment. It tends to dry and harden, sticking to the pins or between the connectors, especially after a longer period.
It would be best to simply lightly dampen the pins with oil using a small brush, meaning just a very small amount; even one drop is sufficient.
Michi
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts ECU Locked: What is WFS? On-Board Diagnostics (OBD)
No new posts Motor-SG locked On-Board Diagnostics (OBD)
No new posts Engine control unit locked? On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Locked? On-Board Diagnostics (OBD)
