Misfires on 2.0 TDI engine, rough running (Solution)
Karma: +806 / -0   Thank you, like it!
Steffen W likes this.
Post16-08-2017, 15:51    Subject: Misfires on 2.0 TDI engine, rough running Quote
A 2.0 PD-TDI 16V (engine code BRE) has an uneven idle and only runs on 3 cylinders (error code P0304 - misfire cylinder 4, similar errors: P0301, P0302, P0303, P0305, P0306). When looking into the engine compartment, the engine exhibits significant shaking in the engine mounts, both in and against the direction of rotation.
As the speed and load increase, the uneven running almost disappears, and only slight vibrations can be felt. During deceleration or when coasting (fuel injection amount 0 mg/H), the engine noise and vibrations are normal.
Reading the error memory with the HEX-V2 and VCDS yields the following:
Wednesday, August 16, 2017, 2:55:42:17557
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 8.1 x64.
VCDS Version: RKS 17.8.0.1 HEX-V2 CB: 0.4401.4
Data as of: 20170809 DS276.3
Vehicle Identification Number: WAUZZZ4F88N0***** License plate:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Address 01: Engine Control Module
Label file: DRV\03G-906-016-BRE.clb
Control unit part number: 03G 906 016 ME Hardware: 03G 906 016 ME
Part and/or version: R4 2.0L EDC G000SG 0945.
Encoding: 0000072
Operating number: WSC 66565 257 00032
VCID: 72BED0A158AB68C75DE-8026
"1 error found:"
000772 - Cylinder 4
P0304 - 000 - Misfire detected
Environmental conditions:
Error status: 01110000
Error priority: 3.
Error frequency: 1
Lost Counter: 255
Mileage: 287,129 km
Time: 0
Date: 2017.08.15
Time: 13:47:27
Speed: 882 RPM
Speed: 0.0 km/h
Last: 0.0%
Voltage: 13.38 V
Injection volume: 2.96 mg/hour.
Temperature: 79.2°C
(no unit): 0.0http://shop.dieselschrauber.de
Unfortunately, there are no electrical faults or interruptions detected in the PD elements within the memory, which is concerning because simple failures in the PD cable harness are almost impossible to rule out.
Since the engine no longer misfires when revving or under no load, the dual-mass flywheel can be ruled out. Are the compression problems caused by issues such as damage to the valve timing mechanism, a crack in the piston, or something similar, or are they due to a defect in the specific positive displacement element?
Removing the cylinder head cover, the first thing that's noticeable is the reduced distance between the top of the pump-nozzle element number 4 and the corresponding rocker arm.
The connecting element between the adjustment screw on the tilting lever and the pressure distribution (PD) element has broken. As a result, the PD element moves to the "not activated" position with each lift, causing the PD element (VAG part number: 03G 130 073 G / 03G130073G) to disintegrate.
 Oberteil von PD-Element des 4. Zylinders liegt direkt am Kipphebel an, die 3 anderen PD-Elemente und Kipphebel sehen normal aus.
 File size:  935.68 KB
 Viewed:  16183 times
 Auch die Betätigungshebel (Verbindungselemente) der übrigen PD-Elemente des 2.0 TDI 16V zeigen leichte Einlaufspuren und Riefen. Ob das normal ist für 287.000km?
 File size:  63.37 KB
 Viewed:  9466 times
 Ausgebrochener Betätigungshebel/Verbindungselement am Pumpe-Düse Element des 4. Zylinders.
 File size:  257.68 KB
 Viewed:  10042 times
Karma: +1355 / -0   Thank you, like it!
Post18-08-2017, 8:14    Subject: Misfires on 2.0 TDI engine, rough running Quote
Does the engine control unit (ECU) detect the combustion misfire based on the current flow of the valve (keyword: BIP - Burn Identification Pulse)? After the somewhat outdated SSP, there is an error message regarding the BIP Control Limit.
Post18-08-2017, 8:20    Subject: Misfires on 2.0 TDI engine, rough running Quote
Hello Herbert,
Theoretically, it's definitely possible, but I have no idea if my engine control unit (ECU) does that. The engine, however, is running so severely unevenly at idle that simply measuring the rotational speed would be sufficient... icon_cool.gif
Post18-08-2017, 8:37    Subject: Misfires on 2.0 TDI engine, rough running Quote
And increasing the idle correction amount has no effect, perhaps the control unit also notices this. These things are supposed to be smart icon_idea.gif.
Post25-08-2017, 19:49    Subject: Misfires on 2.0 TDI engine, rough running Quote
After installing a reconditioned (like-new) PD element from Bosch and new PD connection elements, the PD elements were adjusted. We decided not to disassemble or repair the old PD element, as a deposit is refunded upon its return.
Ratings - Misfires on 2.0 TDI engine, rough running
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Gasoline Engines, Audi, Model Year 2001, Combus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Misfire: 2.4L & 2.8L Motors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Uneven idle speed on the AXR engine Diesel Engine Technology
No new posts Peugeot Boxer: Rough Running - Diagnosis & Repair Diesel Engine Technology
This topic is locked, you cannot edit or reply. 2.0 TDI - Germany - Engine misfiring, white smoke Diesel Engine Technology
No new posts Rough running 1.6 TDI Cayenne, constant injector failure Diesel Engine Technology
