Sharan: Starting problems & engine stalls.
projoe
Post07-10-2017, 19:16    Subject: Sharan: Starting problems & engine stalls. Quote
Hello everyone, I'm new here and I'm having a problem with my Sharan. It's a 1.9 TDI, AUY engine, with 283,000 km on the clock. Unfortunately, it's been almost impossible to start since yesterday morning, it's smoking heavily and misfiring. I read the error memory (VCDS), but no errors were stored icon_confused.gif.
"The preheating system was completely checked and is working correctly. After letting it run for a while and it started up, and I took it for a test drive, it suddenly stalled when I disengaged the clutch and wouldn't start again. After some time and several attempts, it started up again. There are still no error codes stored."
Fuel filter replaced, no change.
Can someone tell me if this issue is a known problem?
Thank you very much.
Translated on 28-09-2026, 12:10.
Karma: +647 / -0   Thank you, like it!
Post08-10-2017, 7:00    Subject: Sharan: Starting problems & engine stalls. Quote
Is he/she/it performing at their best?
Does the AGR close properly? To test it, try putting a piece of metal inside.
Translated on 28-09-2026, 12:11.
projoe
Post08-10-2017, 11:49    Subject: Sharan: Starting problems & engine stalls. Quote
Er läuft auf allen Zylindern. Habe das AGR heute früh dicht gemacht. Uunchanged.
"When it starts cold, it runs roughly and smokes excessively. When I'm driving and the engine is under load, it stalls when I release the clutch and then won't restart. If I drive carefully, avoiding the load, and use a little throttle, it continues to run and even idles. I've already been observing the parameters in VCDS, but I don't see any error codes."
While driving, I feel like there's a slight lack of power, but then I was on the highway, and there was no jerking or hesitation; it accelerates reasonably well until the next gear change.
I've been a mechanic myself for 28 years, but I'm at the end of my rope icon_cry.gif.
Translated on 28-09-2026, 12:12.
Post08-10-2017, 17:03    Subject: Sharan: Starting problems & engine stalls. Translating...
[Translating...]
Autoscan?
Post09-10-2017, 16:14    Subject: Sharan: Starting problems & engine stalls. Quote
Air in the fuel system?
Crankshaft bolt tight?
Greetings.
Guste.
Translated on 28-09-2026, 12:13.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Sliding Door: Repair & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
No new posts VW Polo 1.4 TDI: Starting Issues, Misfires, Stalling Diesel Engine Technology
No new posts AFB Carburetor: Cold Start Problems & Solutions Diesel Engine Technology
No new posts Speedometer Error: Driving Without a Speedometer? Diesel Engine Technology
