oil water heat exchanger
audi 80 tdi
Post28-05-2003, 21:50    Subject: oil water heat exchanger Quote
hello
Is there a specific water flow direction for the heat exchangers on the 1Z TDI engine, or does it not matter?
Best regards, Christian.
donalexo
Post29-05-2003, 15:41    Subject: oil water heat exchanger Quote
You probably mean the oil-water heat exchanger that is integrated into the oil filter flange, right?
Normally, I would say that the flow direction in heat exchangers is not irrelevant, because counter-current heat exchangers are typically used.
However, in these systems, one medium is always used to cool the other.
In an oil-water heat exchanger, the oil is "heated" by the water during the engine's warm-up phase, and then the oil is cooled by the water.
However, in my opinion, the main function is the oil cooling function (please correct me if I'm wrong!). If that is the case, then you need to connect the coolant hoses in such a way that the coolant inlet and the oil outlet are on the same side (from a fluid dynamics perspective).
Is everything alright?
Alex.
Touran 1.9 TDI, EZ 09/2004
audi 80 tdi
Post29-05-2003, 17:28    Subject: oil water heat exchanger Quote
hello
Thank you for the response.
No new posts Ibiza: Where is the NTC water connection? Diesel Engine Technology
No new posts Water-Diesel Mix: Opinions and Reviews Diesel Engine Technology
