TDI mileage
Go to page: 1, 2, 3 ... 14, 15, 16  Next
TDI km gefahren MIT Tuning
< 50.000km
35%
 35%  [ 7 ]
50.000km - 80.000km
25%
 25%  [ 5 ]
80.000km - 120.000km
5%
 5%  [ 1 ]
120.000km - 150.000km
5%
 5%  [ 1 ]
150.000km - 180.000km
10%
 10%  [ 2 ]
180.000km - 210.000km
5%
 5%  [ 1 ]
> 210.000km
15%
 15%  [ 3 ]
Total votes : 20
Karma: +796 / -0   Thank you, like it!
Post24-05-2002, 14:57    Subject: TDI mileage Quote
How long do your tuned TDIs last?
Please provide the engine code (optional), the normal horsepower, the horsepower after a chip tuning, as well as the mileage with the normal engine and the mileage with the chip tuning.
But please only provide the values that were achieved with a single engine icon_wink.gif.
Post24-05-2002, 14:59    Subject: TDI mileage Quote
Engine AHF, 81 kW -> approximately 105 kW.
30,000 km without tuning.
Tuned, 79,000 km.
Translated on 06-07-2026, 2:47.
Post24-05-2002, 15:18    Subject: Does occasional tuning also count? Quote
Engine AFN, 81 kW.
Optional auxiliary power unit (APU) --> approximately 98 kW.
Mileage so far: 32,000 km (I'm a little embarrassed), of which approximately 98% was without any modifications.
SST
Post24-05-2002, 15:22    Subject: TDI mileage Quote
1997 Passat AFN.
Now 100,000 km without any modifications.
So far, no engine problems at 25,000 km. Catalytic converter failure (ceramic material loose).
Translated on 06-07-2026, 2:48.
Stukov
Post24-05-2002, 15:53    Subject: TDI mileage Quote
Can a 75 HP diesel engine with tuning modifications participate in a voting process?
Translated on 06-07-2026, 2:49.
Post24-05-2002, 16:09    Subject: TDI mileage Quote
Stukov wrote:
Is it possible to participate in a vote with a 75 HP TD engine that has been tuned?
Please don't put anything in the selection above, but it's still interesting, so please share your data! icon_razz.gif
olli
Karma: +46 / -0   Thank you, like it!
Post24-05-2002, 16:17    Subject: Re: TDI Mileage/Lifespan Quote
Engine: AEL, 103 kW.
Without tuning: 205,000.
Olli.
Translated on 06-07-2026, 2:50.
D. Kurz
Post24-05-2002, 16:29    Subject: TDI mileage Quote
Passat Variant, '96, 1Z engine, K&N air filter, and EGR valve disabled, approximately 240,000 km driven so far.
In addition, it should be noted that the original cylinder head is still attached (including the gasket!!!) and the original clutch is still installed. At approximately 170,000 km, the mass airflow sensor (MAF) and the turbocharger boost control valve needed to be replaced, and at around 185,000 km, the combination instrument panel failed (at a cost of 480 DM!!!). Therefore, all current mileage readings are approximate.
Dominique.
Lupo-Wolf
Post24-05-2002, 17:36    Subject: TDI mileage Quote
Lupo 1.4 TDI PD with Speed-Buster PD, approximately 90 horsepower (originally 75 hp).
Total 43,000 km with box, approximately 1,000 km icon_redface.gif.
at 30,000 km, the valve cover is leaking icon_evil.gif (the gasket is not available separately!!!)
I'm still looking for someone who can help me with the settings for the engine control unit (it's the same one used in all 1.9 TDI PD engines)!!!
See you later...
André.
Translated on 06-07-2026, 2:52.
Avatar-Jan6K
Post24-05-2002, 17:38    Subject: TDI mileage Quote
Ibiza 6K
Engine ASV.
So far, 8500 km without any modifications.
Previously, I didn't enter anything in the survey to avoid skewing the results, as the mileage is still too low and there's no tuning done yet.
Jan.
Translated on 06-07-2026, 2:53.
rl2664
Post24-05-2002, 17:43    Subject: TDI mileage Quote
AFN engine in a Passat, without modifications: 95,000 km.
At 62,000 km, the catalytic converter and mass airflow sensor were replaced.
Best regards.
Ronny.
Translated on 06-07-2026, 2:54.
Stukov
Post24-05-2002, 17:56    Subject: TDI mileage Quote
Volkswagen Golf 3 TD, 75 horsepower, AAZ engine, 212,000 km. Equipped with an aftermarket intercooler and increased boost pressure of approximately 1.0 bar, resulting in approximately 100 horsepower.
The cylinder head was replaced at 150,000 km.
JET
Post24-05-2002, 20:07    Subject: TDI mileage Quote
Golf IV Variant, engine code AJM, standard 115 HP, 285 Nm torque. With chip tuning: 145 HP, 350 Nm torque. 1500 km driven without tuning, 29000 km driven with tuning. Only issue so far: faulty mass airflow sensor (MAF).
Translated on 06-07-2026, 2:55.
eltipo
Post24-05-2002, 20:19    Subject: TDI mileage Quote
I drive a G4, model year 1999, with an ALH engine, a total of 66,000 km, of which 51,000 km were driven with a performance chip. Currently, it produces approximately 105 kW and 355 Nm of torque.
greetings
Sure, here's the translation:
'eltipo'
Translated on 06-07-2026, 2:56.
Cheffe
Post24-05-2002, 21:03    Subject: TDI mileage Quote
Passat, 1Z model, no modifications, 280,000 km.
So far, no problems icon_biggrin.gif.
*Mario*
Alchard
Post24-05-2002, 21:20    Subject: TDI mileage Quote
Driving a B3 Passat.
Year of manufacture: 1998.
Engine AFN, 81 kW.
Mileage: 155,000 km.
Of those, only the first 5000 km can be driven with a 10 cent surcharge.
'zus.' translates to 'etc.' or 'and so on' in English. Performance? -no idea- ... subjectively: pushes-you-into-the-seat icon_twisted.gif
Best regards, Alchard.
*edit* Now at 233,000 km - no problems so far... the seats are starting to show their age.
Translated on 06-07-2026, 2:57.
