Chiptuning: Tuning Time & Calibration Pressure Impact
dieseltech.ch
2008 Audi A4 Avant Consumption
Post26-10-2017, 8:36    Subject: Chiptuning: Tuning Time & Calibration Pressure Impact Quote
Short question for everyone: I have a chip tuning module installed on my 3.0L CDI engine, which modifies the boost pressure and fuel rail pressure (increasing them).
Will this be visible based on the correction values?
I will definitely read it sometime soon and compare it with your values.
Arbeite mit AUTEL, LAUNCH X431 PADII, VCDS, und Stardiagnose
Fahre einen Audi A4 B8 mit 3.0 TDI Motor (Motorcode CAPA)
Translated on 17-09-2026, 17:29.
Post26-10-2017, 10:01    Subject: Chiptuning: Tuning Time & Calibration Pressure Impact Quote
The corresponding values are determined by the engine control unit at defined rail pressures. If your device "cheats" by reporting an artificially low actual rail pressure to the engine control unit, the actual test pressure will automatically be different, and this can change the timing.
Post26-10-2017, 10:40    Subject: Chiptuning: Tuning Time & Calibration Pressure Impact Quote
The CAPA 3.0 CDI engine with 182,208 km has now been read for the first time. The engine has a chip tuning box installed, which alters the boost pressure and fuel rail pressure. I don't know if this has an influence on the NMK (likely referring to a specific system or component).
However, as I already wrote, this has an influence, and the values are not usable. icon_idea.gif
Translated on 17-09-2026, 17:30.
No new posts Important: Calibration Pressure & Settling Time: Your Input Needed Diesel Engine Technology
No new posts AGR Impact on Engine Efficiency Diesel Engine Technology
No new posts AFN Brake Pedal Influence on Gas Pedal? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Fuel Injectors: Flow Rate & Duration Data Needed Diesel Engine Technology
