Golf III Airbag cables as accessories?
Varianti
Post27-05-2003, 12:42    Subject: Golf III Airbag cables as accessories? Quote
Due to my clumsiness, I did not properly route the airbag cable into the plastic opening at the bottom of the steering wheel. As a result, it got twisted and is now torn. Since this part is quite expensive at VW (109 EUR), I was wondering if anyone has seen this cable in the accessories.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Conditioning Compressor & Accessories Transmission, Chassis, Body & Interior
No new posts Water Pump: Original vs. Aftermarket Diesel Engine Technology
No new posts Upgrading your VW T6 Transporter: Useful Modifications &a... Dieselschrauber Bar
No new posts VAG Check: Compatible PDAs & Accessories On-Board Diagnostics (OBD)
