TDI A4 Jerking: Throttle Position Sensor Issue?
Driver123
Post26-11-2017, 14:12    Subject: TDI A4 Jerking: Throttle Position Sensor Issue? Quote
Hello, I'm having a problem with a 2.0 TDI 143 hp engine.
Severe shaking and vibration starting at 1500-2100 RPM under load.
"Feels" like a broken 2M swing, but it's not.
"Throttle position absolute" should always be at [value] while driving.
87.1% - Okay?
No error entry.
 File size:  22.58 KB
 Viewed:  1918 times
LOG-01-IDE00021_&10.csv
 File name:  LOG-01-IDE00021_&10.csv
 File size:  12.51 KB
 Downloaded:  465 times
 File size:  12.51 KB
 Downloaded:  402 times
Translated on 24-10-2026, 6:03.
Back to top Profile PM Email
Karma: +807 / -0   Thank you, like it!
Post26-11-2017, 14:25    Subject: TDI A4 Jerking: Throttle Position Sensor Issue? Quote
What is the mileage of the vehicle?
You should check if the injectors are functioning correctly and are properly sealed to the cylinder head. The following topic provides information on how to assess the injectors, including normal values:
Ich kann den Inhalt dieser URL nicht abrufen, da ich keinen Zugriff auf das Internet habe. Bitte gib mir den Text, den du übersetzt haben möchtest.
Furthermore, it is possible that there is insufficient compression or mechanical damage to individual cylinders.
Regarding the throttle valve: Check if the actual air mass value follows the desired air mass value in the area where the engine is misfiring. This will help determine if the throttle valve is defective and causing uncontrolled jerking.
Translated on 24-10-2026, 6:04.
Post26-11-2017, 22:01    Subject: TDI A4 Jerking: Throttle Position Sensor Issue? Quote
dieselschrauber wrote:
You should check if the injectors are functioning correctly and are properly sealed to the cylinder head. Here is a topic with normal values for assessing the injectors:
Ich kann den Inhalt dieser URL nicht abrufen, da ich keinen Zugriff auf externe Websites habe. Bitte gib den Text, den du übersetzt haben möchtest, direkt an.
For obvious reasons, the topic only includes values from functioning engines. icon_idea.gif
Translated on 24-10-2026, 6:06.
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPW Shaking on Audi A4 TDI: Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Valve Polo BLT TDI, Up to 2 Bar On-Board Diagnostics (OBD)
No new posts Humming Noise: Constant Frequency Under Load Diesel Engine Technology
No new posts Audi A4 8K, year 2008, engine code CAGA - Engine breather... Diesel Engine Technology
No new posts Torque and tightening angles for CAGA camshaft sprocket Diesel Engine Technology
