dv946
Joined: 11/21/2017 Posts: 8 Karma: +1 / -0 Location: 22949
21-11-2017, 18:11 Subject: Engine Failure: Mystery Solved? |
Hello everyone,
Okay, here's the translation:
"I'm new here, and I'm about to describe a problem. It's a Ford Focus II 2.0 TDCi. The engine has already stalled twice while the car was stationary, before it reached operating temperature. However, the instrument panel lights, such as the oil pressure and airbag indicators, didn't come on. This would suggest that the *ignition* has been cut off, meaning the magnetic valve has closed. It's the same state as if I had turned off the engine using the key. When the engine stalls, everything else turns on. The question is, what triggers this condition? Does the magnetic valve suddenly lose power and close?"
The thought that this happened on the highway, on the left-hand side, makes me quite nervous.
Perhaps some of the members have already encountered this phenomenon. Ford Focus II 2.0 TDCI
Translated on 07-10-2026, 14:18.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2407 Karma: +442 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
22-11-2017, 9:20 Subject: Engine Failure: Mystery Solved? |
I'm not sure which solenoid valve you're referring to.
I would suspect the power supply. It could be the ignition switch itself, or a relay. A less likely, but still possible, cause is a loose connection or a wiring problem.
What is still working and what is not working when the engine and lights are off? Do the windshield wipers and all other consumers still work? After you have narrowed that down, you need to check the wiring diagram to see where they are all powered from. You will probably have found the cause then.
Guste.
Translated on 07-10-2026, 14:20.
Profile PM Garage |
dv946
22-11-2017, 11:53 Subject: Engine Failure: Mystery Solved? |
The solenoid valve is used to stop the engine. The moment I...
Turning the 'ignition' on should cause it to open, allowing fuel to flow. It's located in the fuel supply line to the fuel pump. When I turn the key to the left, it becomes de-energized and closes. This has happened twice without turning the key. However, it started up again immediately. Ford Focus II 2.0 TDCI
Translated on 07-10-2026, 14:21.
22-11-2017, 14:07 Subject: Engine Failure: Mystery Solved? |
You also mention that the oil pressure warning light and other indicators don't light up in case of a fault. This contradicts the idea that the problem is solely due to a defective solenoid valve.
Regarding the rest: Please refer to the previous response.
Translated on 07-10-2026, 14:22.
Profile PM Garage |
dv946
22-11-2017, 14:49 Subject: Engine Failure: Mystery Solved? |
There was no mention of a fault with the solenoid valve itself. Something caused the solenoid valve to close. If I were to stop the engine by force, everything would light up because the "ignition" is still on. In my opinion, something is de-energizing the valve. I'm ruling out an electronic fault because no error codes are stored. Ford Focus II 2.0 TDCI
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
22-11-2017, 15:57 Subject: Engine Failure: Mystery Solved? |
guste100 wrote: | Either the ignition switch itself, or a relay. Less likely, but still possible, is a loose connection or a wiring problem.
Guste | Kaum macht man es richtig, funktioniert es!
Translated on 07-10-2026, 14:23.
Profile PM Garage |
