P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Post08-05-2018, 21:00    Subject: P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 Quote
Error code P246E describes an error at the exhaust gas temperature sensor, position 4 (at the end of the DPF towards the middle muffler), of cylinder bank 1.
Possible causes:
- Defective or burnt-out temperature sensor
- Faulty or interrupted electrical connections to the temperature sensor
Check the sensor readings for plausibility.
Ratings - P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LDA Sensor: Types, Function & Applications Diesel Engine Technology
No new posts What kind of sensor is this? Diesel Engine Technology
No new posts MAP Sensor for AKN Engine On-Board Diagnostics (OBD)
No new posts Exhaust Pressure Sensor BMN On-Board Diagnostics (OBD)
