Seat Ibiza LWR: Too many connection errors
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
nismo-650
Post30-11-2017, 11:11    Subject: Seat Ibiza LWR: Too many connection errors Quote
Hello everyone, I'm new here and wanted to see if anyone might be able to help me with something.
Unfortunately, I can't adjust the basic settings for the xenon headlights because I'm getting an error message (55 LWR) indicating too many communication errors. The connection is constantly being interrupted. Since I don't have a wiring diagram, I've already replaced the altitude sensor. Of course, the new one can't be coded because there are too many communication errors.
"Using a manual adjuster in the light switch, which I currently have on hand, I can regulate the headlight height and also measure the voltage at the actuators. With the original xenon headlight switches, I'm getting 2.89 volts at the actuators. I would be very grateful for your help." Here is the log file.
Wednesday, November 29, 2017, 12:56:43:32571
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 17.8.0.1
Data as of: 20171117 DS276.6
Vehicle Identification Number: VSSZZZ6LZ8R103650
License plate: ZH
Mileage: 145,090 km
Repair order: Daniel Susanszki
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
Mileage: 145,090 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module
Label file: None
Part number: 06A 906 032 QN
Part number: 1.8I R4/5VT G 0020.
Encoding: 11500
Operating number: WSC 04941.
VCID: 7AFC3F9E66A06296C4-5170
VSSZZZ6LZ8R103650 SEZ5Z0G9231901
No error codes found.
Readiness: 0000 0000
Address 03: Brake electronics
Label file: DRV\6R0-907-37x-ESP80.lbl
Part number SW: 6Q0 907 379 AS, Hardware number: 6Q0 907 379 AS.
Part: ESP 8.0 front H05 0003.
Revision: 00000000 Serial number: 00000000000000
Encoding: 0000284
Operating number: WSC 03346 223 184258
VCID: 0E14634E1A285E3608-5154
Address 08: Climate Control/Heating Module. Label file: DRV\6L0-820-043.lbl
Part number: 6L0 820 043 E.
Component: CLIMAtronic PQ24 3805.
Operating Number: WSC 00000 000 00000
VCID: 285835D6988C2006E2-5154
"1 error found:"
01273 - Fresh air blower (V2)
000 - - - Sporadically
Address 09: Central Electronics. Label file: DRV\6Qx-937-049-C.lbl.
Part number: 6Q1 937 049 F.
Part number: 000B BN-SG. 2S36
Encoding: 24972
VCID: 3E74F38E3A088EB6B8-5170
Address 15: Airbag Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 AE
Part number: 0H AIRBAG VW5 0C 0010.
Encoding: 12360
Address 17: Control panel module
Label file: DRV\6L0-920-xx3-17.lbl
Part number: 6L0 920 823 G
Part: AGD V04 COMBINATION INSTRUMENT.
Encoding: 02101
Operating number: WSC 00000
VCID: 316ED8B2FB5661CE35-5170
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Part number: 0305 GATEWAY CAN 2S36.
Encoding: 00014
VCID: 70E81DB630DC28C67A-5170
Address 25: Immobilizer
Label file: DRV\5J0-920-xxx-25.clb
Component: IMMOBILIZER AGD V04.
Encoding: 02101
Address 44: Steering Assist
Label file: DRV\6Q0-423-156.clb
Part number: 6Q0 423 156 AB
Component: Steering assist TRW V270.
Encoding: 10121
VCID: 6FEA1ECA2DE2373E63-5170
Address 46: Comfort System Label File: DRV\6Q0-959-433.clb
Part number: 6Q0 959 433 E.
Component: Comfort device 0002.
Encoding: 00019
Operating number: WSC 03346.
VCID: 3D76F482370E95AEA1-4B30
Address 55: Headlight range adjustment. Label file:
VCID: 55A64C22AC7E6DEE89-51CA
Note: Too many communication errors.
End----------------------------(Duration: 03:31)-----------------------------
Post30-11-2017, 11:42    Subject: Seat Ibiza LWR: Too many connection errors Quote
Unfortunately, I can't adjust the basic settings of the xenon headlights because I'm getting an error message indicating "55 LWR," which means there are too many communication errors. The connection is constantly being interrupted.
The connection to the other control units is working, so I would check if the wiring to the LWR control unit is okay and that it hasn't been damaged by water ingress.
nismo-650
Post30-11-2017, 11:59    Subject: Seat Ibiza LWR: Too many connection errors Quote
Best regards, Rainer
Hello Rainer,
Thank you for the quick response.
The LWR control unit is integrated into the LWR sensor located on the rear axle, and that sensor has already been replaced.
To make sure I understand correctly, when you say "waterlogged," are you referring to a specific location that is experiencing water damage, or are you referring to a different control unit?
I also suspected the body control module, but without a wiring diagram, it's difficult to determine whether the body control module is related to the automatic headlight range adjustment.
"Thank you in advance."
Best regards, Daniel.
Post30-11-2017, 12:04    Subject: Seat Ibiza LWR: Too many connection errors Quote
Hello Daniel,
If the body control module is functioning normally and is accessible, it is highly unlikely that it is related to the automatic headlight range adjustment problems.
If the LWR control unit is new, I would carefully inspect the connectors and cables leading to it.
nismo-650
Post30-11-2017, 12:17    Subject: Seat Ibiza LWR: Too many connection errors Quote
Hello Daniel,
Hello Rainer,
Thank you for your help.
I will do that right away and report back.
I hope I can find some information regarding the pin assignments.
"The body control module is normally accessible, which is a bit strange because in position 0 on the light switch, all the lights turn on in this vehicle, even though daytime running lights (DRL) should only activate the low beams. Unfortunately, I haven't found anything to change this through coding." Was this done intentionally by Seat?
Post30-11-2017, 12:28    Subject: Seat Ibiza LWR: Too many connection errors Quote
Hi Daniel,
I have no idea what all the lights are supposed to illuminate on that Skoda when it comes to "daytime running lights." My Audi also has more lights on than I would personally prefer, but okay. icon_confused.gif
Regarding circuit diagrams and pin assignments:
You can find wiring diagrams and more for your car at Erwin (siehe Fehlerdatenbank) for Skoda.
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Geschwindigkeitsregelanlage nachrüsten Seat IBIZA / Polo Troubleshooting & Guides
No new posts VW Lupo GTi LWR zu viele Verbindungsfehler mit LWR Electrical Systems, Vehicle Electronics, Multimedia
No new posts GRA und Seat Ibiza Bj 11/98 Diesel Engine Technology
No new posts Fahrwerkbericht Seat Ibiza 6K AFN Transmission, Chassis, Body & Interior
No new posts Startprobleme Seat Ibiza (AHU) Diesel Engine Technology
