Engine BMM, camshaft sensor error
Massimo
Post26-01-2018, 21:32    Subject: Engine BMM, camshaft sensor error Quote
Hello everyone,
I'm having a problem with a Skoda Octavia 2.0 TDI BMM. I replaced the engine because it was running on only three cylinders. I installed a used engine and immediately replaced the timing belt and water pump. I transferred the high-pressure diesel injection system (PDE) from the old engine, except for the cylinder that was defective.
The engine is now completely installed. I started it, and now I'm having a problem: it's difficult to start, but once it starts, it runs normally.
It indicates an implausible camshaft position sensor reading as an error. I installed a new sensor. I checked the wiring from the connector to the engine control unit for continuity, and I re-checked the timing belt. Everything seems to be okay... maybe you can help me.
Sincerely,
Massimo.
Post26-01-2018, 21:55    Subject: Engine BMM, camshaft sensor error Quote
We cordially invite you to participate. The prerequisites for posting in diagnosis-related topics and for diesel engine technology are a diagnostic device from the Dieselschrauber Shop or a KDataScope, KPower, or Dieselschrauber license, or a support key.
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentation: Performance Issues, Error 17964, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance Issues, Error 17707, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi camshaft sensor - broken wire? Diesel Engine Technology
No new posts Timing Belt Failure & Camshaft Sensor: Causes & F... Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf4TDI AJM Notprogramm Nockenwellensensor/Hoehengeber On-Board Diagnostics (OBD)
No new posts Passat 3C (2007): ELV & Engine Problems On-Board Diagnostics (OBD)
