Audi A6 2.5 TDI: Air in Fuel Line - Fix It!
AudiHeiko96
Post18-10-2017, 8:46    Subject: Audi A6 2.5 TDI: Air in Fuel Line - Fix It! Quote
"Hello, for the past few days, I've been having a problem with air in my fuel line. When I bleed the diesel filter, the bubbles mostly disappear, but then only very tiny bubbles remain. Are these normal? I'm quite desperate. The fuel injection pump is new, as are all the fuel lines to the ESP, the diesel filter, and the fuel filter housing."
What I've also noticed is that there are a lot of bubbles coming from the return line (I've installed a section of transparent tubing).
Thank you in advance for any suggestions icon_smile.gif.
Translated on 30-08-2026, 0:04.
Bergamount
Post17-01-2018, 7:38    Subject: Audi A6 2.5 TDI: Air in Fuel Line - Fix It! Quote
Is there a problem when starting? I remember the engine being very sensitive to air intake before... I've already tried bleeding the system. But first, let's figure out what the actual problem is.
Translated on 30-08-2026, 0:05.
Post17-01-2018, 9:56    Subject: Audi A6 2.5 TDI: Air in Fuel Line Problem Quote
AudiHeiko96 wrote:
I also noticed that there are quite a few bubbles coming from the return line.
Then you've probably already found the cause.
If air is entering the reservoir (RL), it's also likely getting into the ventilation system (VL) through the "Knackfrosch" (presumably a component). Therefore, you need to find the source of the air entering the reservoir. I'm not familiar with the 2.5L engine. Is the air intake control element (AKE) still a vacuum-operated system (VEP) with an electronic sensor (ESD), or is it already a pressure-driven (PD) system? If it's still a vacuum system, I would start by replacing the breather hoses, as they are known to cause air leaks.
Greetings.
Guste.
Translated on 30-08-2026, 0:07.
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 Brake Light: Troubleshooting & Repair Diesel Engine Technology
No new posts Audi 2.5 TDI: Alternative Fuel Options Diesel Engine Technology
No new posts TDI Diesel Air Intake Hose for Audi Diesel Engine Technology
This topic is locked, you cannot edit or reply. Audi A6 Air in Fuel System: 2.5 TDI AKN Fix Diesel Engine Technology
