Fuel System: How to Bleed Properly
RifLeb
Post08-01-2018, 21:59    Subject: Fuel System: How to Bleed Properly Quote
I have a Passat 1.6 TDI (engine CAYC) from the year 2010, and I have a question:
'High-pressure pumps should not run dry, otherwise shavings can be generated. How do you properly bleed the system when there is air in the high-pressure system (e.g., due to a high-pressure pump replacement or work on the fuel lines)? Is it sufficient to simply activate the fuel pump for pre-charging in the tank using VCDS? Does the fuel then flow through the entire system, including the high-pressure system? Finally, there is already a return hose from the fuel filter to the tank. After the high-pressure pump, there are also 2 valves (1 valve directly on the fuel rail, 1 pressure regulating valve for the fuel rail, and 1 pressure relief valve on the return line). The pressure must first be overcome before anything can reach the return line from the high-pressure system?'
Sure, here's the translation:
'Thank you in advance!'
Translated on 23-09-2026, 5:53.
Post17-02-2018, 12:32    Subject: Fuel System: How to Bleed Properly Quote
Using VCDS to activate the fuel pre-pump will fill the new, empty diesel filter. This process does not flush the high-pressure system, and it doesn't need to.
Translated on 23-09-2026, 5:55.
No new posts Fuel system bleeding - Audi A4 3.0 TDI BKN Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0171 Fuel System Bank 1 Lean Mixture Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1 GTD: Bleed Fuel System - How To Diesel Engine Technology
No new posts Opel Movano BJ 2002 MKB G9T Kraftstoffsystem entlüften Diesel Engine Technology
No new posts Bleed the fuel system of a CFFB engine after filter repla... Diesel Engine Technology
No new posts 1.4 TDI: Air in Fuel System? Diesel Engine Technology
