tdi-seppl Blaumann
Joined: 02/01/2003 Posts: 44 Karma: +6 / -0 Location: Regensburg
19-02-2018, 19:58 Subject: Faulty Glow Plugs: Causes & Solutions |
hello,
"In my Audi A4 B8 2.0 TDI CR, all the glow plugs are defective. There's a constant voltage of 11.9 volts at the connector on the glow plug cables, even when the Audi is turned off. However, the glow plugs themselves require only 4.4 volts. Where is this high voltage coming from? Is the control unit defective?" Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 30-08-2026, 12:41.
Herbert Profi-Schrauber
19-02-2018, 20:36 Subject: Faulty Glow Plugs: Causes & Solutions |
Constantly, i.e., even with a warm engine?
Do you ever get a car scan done?
Herbert. Horch A4 8K CJCD
Translated on 30-08-2026, 12:42.
tdi-seppl Blaumann
19-02-2018, 22:26 Subject: Faulty Glow Plugs: Causes & Solutions |
"Yes, even if the engine is warm, unfortunately, I don't have a VCDS." Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
19-02-2018, 22:34 Subject: Faulty Glow Plugs: Causes & Solutions |
That would be useful here!
