Brake Stuck After Bleeding? 3BG PD TDI
dafe
Post20-03-2018, 12:33    Subject: Brake Stuck After Bleeding? 3BG PD TDI Quote
I would like to share a surprising observation:
After two attempts to fix the sticking front left brake (hot rim during highway driving, now okay), I had to bleed the brakes. After working on the last front left wheel, it turned out that both front brakes were completely seized, and the wheels couldn't be turned.
Removed and reinstalled the ABS and ESP fuses, disconnected the battery, checked the pressure relief valve, and then there was a loud bang and a big problem on the side street in the new development area.
My son and helper said, "Hey, there's a plastic part near the brake pedal, and it doesn't look like it belongs there." What the...? icon_eek.gif
Kurz und gut, über dem Bremspedal ist eine dreieckförmige Abdeckung ohne Befestigung am unteren Ende. Wenn das Bremspedal zum Entlüften durchgedrückt wird, hakt es zwischen Pedal und Hebelstange ein, Wirkung wie Feststellbremse. Sieht fast schon aus wie design by purpose. UngIncredible.
Perhaps this information will be useful to someone.
Translated on 29-10-2026, 21:09.
Karma: +807 / -0   Thank you, like it!
Post20-03-2018, 15:33    Subject: Brake Stuck After Bleeding? 3BG PD TDI Quote
Never seen it before, but thanks for the info icon_smile.gif. Is there a picture?
Translated on 29-10-2026, 21:10.
dafe
Post20-03-2018, 22:41    Subject: Best German Restaurants: Find Top Rated Dining Quote
..try to make one soon, when the mountain of work has been cleared icon_rolleyes.gif.
Translated on 29-10-2026, 21:11.
dafe
Post23-03-2018, 18:15    Subject: Criminals: Definition, Types & Examples Quote
This is what a brake looks like when it's ready for operation.
 Hier hebe ich die dunkelgraue Kunststoffabdeckung an. Bei Durchtreten gelangt das Pedal unter die Abdeckung und blockiert die Bremse sehr wirkungsvoll. Man kann also z.B. Fahrrad fahren gehen...
 File size:  1.06 MB
 Viewed:  399 times
klahaui
Avatar-klahaui
2019 Volkswagen Golf
dieselschrauber likes this.
Post23-03-2018, 19:16    Subject: Brake Stuck After Bleeding? 3BG PD TDI Quote
Evening.
That's probably a retaining clip from the trim icon_smile_thumb_up.gif. It shouldn't happen if it's properly installed.
dafe
Post23-03-2018, 22:44    Subject: Brake Stuck After Bleeding? 3BG PD TDI Quote
It was like that from the factory. I didn't do anything or install anything. In this case, four eyes really saw more than two.
Translated on 29-10-2026, 21:12.
Post24-03-2018, 12:18    Subject: Brake Stuck After Bleeding? 3BG PD TDI Quote
klahaui wrote:
Evening,
That's probably a retaining clip from the trim. icon_smile_thumb_up.gif With proper installation, that shouldn't happen.
I also think so icon_wink.gif. Nevertheless, thank you for the feedback.
dafe
Post24-03-2018, 14:18    Subject: Brake Stuck After Bleeding? 3BG PD TDI Quote
I've received help from you before. That's why I'm happy to return the favor whenever I can.
Thank you all.
Translated on 29-10-2026, 21:13.
No new posts TDI Fuel Pump Priming: How to Bleed It Troubleshooting & Guides
No new posts Document A3 to MJ 98, door panel blocked Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Bleed brakes with ABS, Bosch version 5.3 Diesel Engine Technology
No new posts Rear brake hot after replacement Transmission, Chassis, Body & Interior
No new posts Coolant pump / Filling and bleeding Diesel Engine Technology
No new posts VP44 Bleeding: How to Bleed Your Injection Pump Diesel Engine Technology
