Crankshaft bolt torque specification ALH G4
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post05-05-2008, 18:41    Subject: Crankshaft bolt torque specification ALH G4 Quote
Does anyone happen to know the torque specification for tightening the crankshaft bolt on a VW Golf 4?
Volkswagen Golf 4, manufactured in 1999.
ALH engine, 90 horsepower.
is there still one with a VEP?
The screw is an M16x54 mm.
Translated on 18-07-2026, 12:33.
Post05-05-2008, 18:50    Subject: Crankshaft bolt torque specification ALH G4 Quote
120 Nm and then rotate another 90 degrees.
Best regards, Raier.
Translated on 18-07-2026, 12:34.
Gremlin
Avatar-Gremlin
Post05-05-2008, 19:18    Subject: You're welcome! Quote
That was quick icon_lol.gif.
Thank you.
efistho
Post07-05-2008, 15:40    Subject: Crankshaft bolt torque specification ALH G4 Quote
For the older engines, it was always 90 Nm and 90 degrees. (1Z AFN AHU)
I thought it was still there, but I'm not sure without a guide.
Best regards, efistho.
Translated on 18-07-2026, 12:35.
Wiesel
Post07-05-2008, 19:45    Subject: Crankshaft bolt torque specification ALH G4 Quote
You're right about the old engines.
For the ALH (and for the ASV, for example), it is the torque of 120 Nm plus an angle of 90°.
Best regards, Micha.
Translated on 18-07-2026, 12:36.
Schorsch68
Post11-03-2018, 11:19    Subject: Crankshaft bolt torque specification ALH G4 Quote
10 years later...
On the 1.9-liter engines, with the transition to hulls without an intermediate shaft (ASV), and the ALH and PD models, the central bolt was changed from M14 to M16.
That's why the other torque value is different...
Best regards, Schorsch.
Translated on 18-07-2026, 12:37.
Schorsch68
dieselschrauber likes this.
Post31-03-2018, 14:32    Subject: Crankshaft bolt torque specification ALH G4 Quote
Because it's interesting...
Not only was the screw changed, but the diameter of the KW stub has also increased by 3 mm.
It's clearly visible on the bridge between the four M8 threads and the KW (shock absorber) mounting point.
 File size:  115.41 KB
 Viewed:  1458 times
Translated on 18-07-2026, 12:38.
No new posts Cylinder Head Bolt Torque Specs 1Z Diesel Engine Technology
No new posts Tightening Torque: 16V PD Camshaft Diesel Engine Technology
No new posts Crankshaft Screw TDI Diesel Engine Technology
No new posts Crankshaft Bolt for TDI 90 PS (ALH) Diesel Engine Technology
