Soot Mass Negative: Audi A3 P8 2.0 TDI CR
franz12345
Post10-04-2018, 9:07    Subject: Soot Mass Negative: Audi A3 P8 2.0 TDI CR Quote
Year of construction: 2010.
Every 3 to 4 weeks, a "Diesel Particulate Filter" warning light illuminates on the instrument panel. It usually disappears after a longer drive. Since this has been happening more frequently, I decided to investigate.
No error codes are present, but the measured soot mass is negative. I installed a new differential pressure sensor and calibrated it using the basic settings. The measured soot mass is still negative.
The instructions state that you can program it using "Coding 2." However, I can't click on that field in the vehicle's settings.
Does anyone have any ideas?
Thank you very much.
 File size:  61.81 KB
 Viewed:  1243 times
Translated on 02-09-2026, 5:08.
Post10-04-2018, 9:55    Subject: Soot Mass Negative: Audi A3 P8 2.0 TDI CR Quote
As a customer who purchased your vehicle from a dealership, you are unfortunately not entitled to support. Diagnostic-related inquiries are exclusively reserved for our customers who have had diesel engine work performed.
The following option is available:
Vehicle Diagnostics Support Key
Translated on 02-09-2026, 5:10.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF soot mass measured as too high Diesel Engine Technology
No new posts 2.0 TSI ignition timing temporarily negative during accel... Gasoline Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
