cz26m Guest
15-12-2003, 22:21 Subject: Injector Replacement: AFN to 216 Upgrade |
hi!
I'm very interested in following your discussions and experiences with the larger nozzles. You've made me so eager now; I WANT TO EXCHANGE THEM TOO. But I'm a beginner and have no idea how. I know where they are located, but I've never exchanged the nozzles before. I've chosen two numbers here: from AXG Motor (074 130 201 t) and (074 130 202 r). Are these the correct nozzles? And how do I exchange them? I've read that you have to pay attention to the position of the nozzles when you screw them in, and that you should also replace some copper plates.  What kind of position are we talking about? What else do I need to replace? I'm afraid of doing something wrong and damaging the engine. I now have an auxiliary box before the pump, and this unit is producing a lot of soot; I would like to get rid of that with the new nozzles. Thank you in advance for your answers.
look, Chris.
Translated on 13-08-2026, 19:22.
christians Profi-Schrauber
15-12-2003, 22:39 Subject: Injector Replacement: AFN to 216 Upgrade |
search: fuel injectors
That probably contains most of the information.
"Nuts with an M14x1.5 thread for use with nozzles are not exactly a common item you'll find at hardware stores. However, they are often used to attach shock absorbers to the strut mount. I had quite a few of them in a box."
Gruß Christian
Translated on 13-08-2026, 19:23.
PrivatBereich Guest
16-12-2003, 10:30 Subject: Injector Replacement: AFN to 216 Upgrade |
If you really have no idea what you're doing, I would recommend having them replaced by a Bosch service center. It doesn't take forever, so it probably won't be too expensive.
And at least then the guys know what they're doing. If you happen to get dirt into the engine or install them incorrectly, the engine can quickly be damaged. So I would say: invest those estimated 50 euros and have it done professionally.
If not, then use the search function, as several people have already written about proper cleaning and replacement.
-Private
Translated on 13-08-2026, 19:25.
Julian Guest
16-12-2003, 10:38 Subject: Injector Replacement: AFN to 216 Upgrade |
Invest the estimated 50 Euros and just do it.
Good tip, but they won't work for half an hour for €50... it doesn't go that fast.
Translated on 13-08-2026, 19:26.
Arne Guest
16-12-2003, 11:23 Subject: Injector Replacement: AFN to 216 Upgrade |
Well... it's actually quite quick to do. We took about three-quarters of an hour last week. I would recommend getting it done if you don't have much experience with it yourself. That way, at least you can drive with peace of mind.
arne
16-12-2003, 21:25 Subject: Injector Replacement: AFN to 216 Upgrade |
I just finished that myself. Time is running out. Of course, that's only if you're lucky and all the nozzles come loose easily, and the little sealing rings stay stuck to them.
But what's really the big deal? The nozzle holders aren't fixed 100% by the claws, but there isn't much play. If it were that critical, surely someone would have come up with a more precise solution. Of course, you shouldn't install them upside down (180 degrees), as that will cause problems.
Gruß Christian
Translated on 13-08-2026, 19:27.
Arne Guest
17-12-2003, 9:09 Subject: Injector Replacement: AFN to 216 Upgrade |
Ulf once wrote a short note about it; apparently, one of the nozzles wasn't perfectly aligned within its holder, which caused a strange noise. I made sure everything was precisely aligned on my end and haven't had any problems.
arne
Translated on 13-08-2026, 19:28.
Thomas Profi-Schrauber
Joined: 04/17/2002 Posts: 329 Karma: +2 / -0 Location: Darmstadt
17-12-2003, 10:34 Subject: Injector Replacement: AFN to 216 Upgrade |
The injectors have some play within this bracket/holder. If the nozzles are not centered correctly, this can easily affect the combustion noise. If the nozzle is properly seated, the engine sounds a bit smoother.
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 13-08-2026, 19:29.
17-12-2003, 10:41 Subject: Injector Replacement: AFN to 216 Upgrade |
I mounted it in the middle based on my feeling, but I'm not sure if that was actually the center.
Gruß Christian
Translated on 13-08-2026, 19:30.
17-12-2003, 10:47 Subject: Injector Replacement: AFN to 216 Upgrade |
I always do it based on my feeling too, and I'm sure that it's not 100% accurate. At VW, they don't pay any attention to that at all. They just put the parts in, tighten them, and that's it. They don't care whether they are centered or positioned correctly in any way.
Greetings.
Thomas.
As I said, I only felt like the engine was running a little bit "better."
Translated on 13-08-2026, 19:31.
Arne Guest
17-12-2003, 12:00 Subject: Injector Replacement: AFN to 216 Upgrade |
Well, what do you mean by 'feeling'? You can still see a gap of about 0.5mm between the nozzle sides and the guide. I shone a flashlight on it and could immediately see whether they were perfectly centered or just relatively centered. Then I adjusted them with a size 15 screwdriver, I think. Whether it made a difference... I think so.
But you're right. The VW technician I consulted with when I was replacing the injectors just said it didn't matter and that they wouldn't pay attention to it. Just tighten them properly and that's it.
arne
Translated on 13-08-2026, 19:32.
cz26m Guest
20-12-2003, 17:22 Subject: Injector Replacement: AFN to 216 Upgrade |
Thank you for your replies. I searched the forum again and found some helpful tips. I will have a friend help me replace the nozzles.
'Thank you, Chris.'
Translated on 13-08-2026, 19:33.
Jan03 Blaumann
Joined: 08/24/2003 Posts: 142 Karma: +6 / -0 Location: Dänemark 2010 Volkswagen Polo Free account, no CAN development support
23-12-2003, 6:13 Subject: Injector Replacement: AFN to 216 Upgrade |
Are you sure that centering method will work? I tried it too and tightened them to the specified torque, but when I tightened the sprinkler line, the alignment went off again.
Greetings.
January.
Translated on 13-08-2026, 19:34.
Profile PM Garage |
donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
23-12-2003, 8:04 Subject: Injector Replacement: AFN to 216 Upgrade |
Hello Jan!
You'll need to use a wrench on the nozzle holder to prevent it from twisting while tightening the union nut of the injector line.
"Only the DHK models with NBF might present problems, as there isn't an accessible key area (as far as I remember)."
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 13-08-2026, 19:35.
Arne Guest
23-12-2003, 15:16 Subject: Injector Replacement: AFN to 216 Upgrade |
I held onto the NHG with pliers  .
I tried to keep it as gentle as possible while the technician tightened the locking nut with... I believe it was 25 Nm of torque.
arne
Translated on 13-08-2026, 19:36.
