Error code P1115, Overvoltage Temperature Sensor (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Post09-03-2019, 16:03    Subject: Error code P1115, Overvoltage Temperature Sensor Quote
Error code P1115 is a manufacturer-specific error code that is set when either the measured voltage (output voltage) at the coolant temperature sensor or the intake air temperature sensor is too high.
Due to electrical wiring, faulty temperature sensors or damaged cable bundles to the respective sensor are usually the cause.
The engine control unit cannot set the correct operating parameters without the correct engine temperature or intake temperature. This results in increased fuel consumption and reduced performance. Sometimes, there may also be starting problems.
Ratings - Error code P1115, Overvoltage Temperature Sensor
No new posts P2185 - Coolant Temperature Sensor, High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P1351 General Tips
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kühlwasserverlust - am Temperatursensor Diesel Engine Technology
No new posts Coolant Temperature Sensor AFN Diesel Engine Technology
No new posts Temperature Sensor Location: Installation Guide Diesel Engine Technology
No new posts Position Temperature Sensor Transmission, Chassis, Body & Interior
