Volvo T5 VCDS?
New Topic 🔒 Locked 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
Dejan
Post12-04-2018, 23:45    Subject: Volvo T5 VCDS? Quote
Hello everyone,
I'm currently selling my Audi A4 TDI because we've moved to a place located on a mountain. I need an all-wheel drive vehicle.
I think this forum is really awesome!
There's an answer for everything! Keep up the good work!
I was able to get a Volvo for the family, a V50 T5 AWD... from 2010 with 100,000 km.
I'm now worried that I might not be able to use VCDS anymore, and also whether gasoline car owners are welcome at a diesel mechanic's shop icon_wink.gif.
Does the funct vcds also work with Volvo?
Dejan.
Post13-04-2018, 7:05    Subject: Volvo T5 VCDS? Quote
You can use the OBD-II button in VCDS, or KOBD2Check. However, KOBD2Check only provides basic diagnostics and not as in-depth information as you get with VAG models.
whether gasoline drivers or diesel mechanics are welcome
Why shouldn't it be that way, especially since there's a section called "Gasoline Engines - Engine Technology" where you write? icon_cool.gif
hVgti
2010 Volkswagen Golf
Post29-06-2018, 18:42    Subject: Volvo T5 VCDS? Quote
My father also has a V50 from 2009. However, a D5.
I was just trying to access the vehicle's systems using VCDS via the EOBD2 interface, but it didn't work.
VCDS reports after a few seconds that a connection cannot be established.
Golf 6 GTI - DSG - MKB: CCZB - MJ: 2011
Post29-06-2018, 19:59    Subject: Volvo T5 VCDS? Quote
Then he should probably use KOBD2Check instead...
No new posts OBD diagnosis for Volvo V70 On-Board Diagnostics (OBD)
No new posts kraftstoffeinspritzmenge msa15.7 volvo tdi Upload
No new posts Which software/cable for Volvo V70? On-Board Diagnostics (OBD)
