What adhesive should be used to glue a turbocharger boost hose?
reuselkopp
Post30-07-2018, 8:18    Subject: What adhesive should be used to glue a turbocharger boost hose? Quote
Hello everyone,
I'd like some advice or a tip from you. We have a Smart CDI in our family's fleet of vehicles. The Smart keeps leaking oil from the connection between the turbocharger pressure hose and the mixer housing, towards the oil cooler. The connection is a peculiar type of connector that is often used by VAG (Volkswagen Group). Unfortunately, a completely new hose hasn't improved the situation. Wrapping the connector with tape also didn't help. I remember reading something about gluing it in this forum, but I can't find the thread anymore. What kind of adhesive or sealant can I use here?
Thank you and best regards.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 05-07-2026, 22:47.
Post30-07-2018, 8:52    Subject: What adhesive should be used to glue a turbocharger boost hose? Quote
Oil-/fuel-resistant silicone?
Translated on 05-07-2026, 22:48.
reuselkopp
Post30-07-2018, 10:10    Subject: What adhesive should be used to glue a turbocharger boost hose? Quote
Hello Rainer,
Thank you for your tip. I just ordered Mannol 9912, which should work.
Reuselkopp.
Translated on 05-07-2026, 22:49.
haithamina
Post01-08-2018, 13:11    Subject: What adhesive should be used to glue a turbocharger boost hose? Quote
Hello reuselkopp.
"Back then, in the 11th grade, I used a silicone tube from a hardware store (and documented it here in a thread). It worked very well." I cannot say how easy or difficult the disassembly would be.
I am unable to translate "haithamina" because it does not appear to be a word or phrase in the German language. It may be a misspelling, a proper noun, or a term from a specialized field. If you can provide more context or clarify the intended meaning, I would be happy to assist you with the translation.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts Where to attach the boost pressure hose Diesel Engine Technology
No new posts Replace the charging hose at the turbo (AMF) Diesel Engine Technology
No new posts Thick-walled intake air hose for turbo Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI Tuning... bis zu welchem KM-Stand? Diesel Engine Technology
