Common-Rail TDI with knocking noises between at 1400 RPM
mcgregg
Karma: +7 / -1   Thank you, like it!
Post24-08-2018, 5:27    Subject: Common-Rail TDI with knocking noises between at 1400 RPM Quote
Hello everyone!
"On my Skoda Octavia, manufactured in 2012, with a 2.0L Common-Rail diesel engine (140 hp, engine code CFHC), I'm experiencing knocking noises under moderate load, between 1200 and 1600 RPM. The noises disappear when I accelerate. It sounds like an older diesel engine from the pre-TDI era. With a Common-Rail diesel, I suspect that the pre-injection timing might be incorrectly calibrated." Otherwise, the engine is running perfectly.
Does anyone have any ideas what might be causing this? What can I check? VCDS is available.
mcGregg
Skoda Octavia II Combi TDI, 2012, 103kW/140PS MKB CFHC
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber likes this.
Post24-08-2018, 13:53    Subject: Common-Rail TDI with knocking noises between at 1400 RPM Quote
Yes, I'm familiar with that issue from the 3.0L and 2.7L V6 TDI engines, and as you suspect, it's due to the pre-injection.
"In my case, this issue occurs sporadically under varying load conditions and at different temperatures (both coolant and ambient temperatures)."
You can easily view the pre-injection dosage values in the measurement data sheets. I don't know the exact specifications for your engine right now.
When the engine is misfiring, you can see that the pre-injection is being set to 0.0. If the engine suddenly becomes quieter, the measured value will change to a positive value.
However, I haven't yet been able to determine exactly which sensors, data, or measurements are being used to control it.
I have a faulty fuel temperature sensor (short circuit/open circuit without an error code icon_eek.gif because, in case of failure, the engine temperature is immediately used as a substitute).
I switched and got a slight improvement (nail biting occurs less frequently).
I also replaced the coolant temperature sensor three months later, which slightly reduced fuel consumption, but didn't affect the knocking sound.
I also had the LMM (likely referring to a mass airflow meter) replaced due to mileage, which the automatic transmission appreciated. However, the knocking sound hasn't changed.
Now I'm focusing on the rail pressure sensor or the rail pressure regulator, but it still needs some more data logs and test drives for proper diagnosis.
You could check the rail pressure on your car to see how it behaves when it's misfiring, and then when it stops, to see if it fluctuates, increases, or decreases, etc.
That's all based on my experiences so far.
Regards, Mpire.
Marco_Gorski
Post07-09-2018, 22:50    Subject: Common-Rail TDI with knocking noises between at 1400 RPM Quote
Hey, I'd like to help you find your mistake.
Can you read the injection values of the injectors?
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI with Common Rail: Explained & Benefits Diesel Engine Technology
No new posts Common Rail vs. TDI: Which is Better? Diesel Engine Technology
No new posts Common Rail Injectors: LT 35 Refurbishment? Diesel Engine Technology
No new posts Common Rail Tool Set for Timing Belt Replacement Diesel Engine Technology
