Outdoor Temperature Display Malfunction!
Brösel
Post11-06-2003, 10:23    Subject: Outdoor Temperature Display Malfunction! Quote
Is my outdoor temperature display inaccurate?
Translated on 14-08-2026, 1:41.
vikinger
Post11-06-2003, 11:31    Subject: Outdoor Temperature Display Malfunction! Quote
I'm experiencing similar issues. The display initially shows incorrect information, but after a few minutes of driving, it eventually displays the correct value. However, I haven't really thought about what might be causing this yet.
Translated on 14-08-2026, 1:42.
PrivatBereich
Post11-06-2003, 13:59    Subject: Outdoor Temperature Display Malfunction! Quote
IMHO, it could also be due to water or moisture on the sensor. In that case, a slight evaporative cooling effect would occur initially, and the temperature of the water droplet would be displayed. Once the moisture evaporates, the sensor temperature would rise to match the outside air temperature.
Just a thought...
Julian
Post11-06-2003, 14:30    Subject: Outdoor Temperature Display Malfunction! Quote
HI!
It happened to my Golf 4 too. If the sensor (located in the black grid below the driver's headlight in the bumper) is definitely dry and clean, then try removing the sensor and cleaning its contacts.
If that doesn't help, the only solution is to replace the sensor, which isn't very expensive. It's not a problem with the instrument cluster!
Translated on 14-08-2026, 1:43.
Julian
Post12-06-2003, 6:21    Subject: Outdoor Temperature Display Malfunction! Quote
Well, mine was also a bit slow to respond. I parked it in the shade, and it only showed 15°C (59°F), even though it was already 30°C (86°F) outside. The climate control system then operated at a reduced level.
After some time, the temperature suddenly increased dramatically. I would replace it!
Translated on 14-08-2026, 1:44.
Uwe
Post12-06-2003, 9:08    Subject: Outdoor Temperature Display Malfunction! Quote
Hi!
There are two temperature sensors: one in the bumper and another in the air box, within the airflow of the interior ventilation system. It is likely that ONE of these sensors is providing an implausible reading.
You can query the values using the Climacodes. For Audi, it's channels 58 and 59, while for VW, I believe it's different channels. This allows you to check the sensors with minimal effort.
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 14-08-2026, 1:45.
Julian
Post12-06-2003, 10:01    Subject: Outdoor Temperature Display Malfunction! Quote
Okay, but the module located in the dashboard isn't responsible for the display of tire pressure information on the instrument cluster or multifunction display; that's solely the responsibility of the module located in the bumper!
Translated on 14-08-2026, 1:46.
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3: Faulty Fan Repair & Service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4/A6 Doku: Faulty Fan Control System Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine RPM and Outside Temperature in AI On-Board Diagnostics (OBD)
No new posts Diesel Consumption: How Temperature Affects Fuel Use Diesel Engine Technology
No new posts EDS System Error: Troubleshooting & Fixes Diesel Engine Technology
No new posts Steering Sensor Error: Replaced Slip Ring, ESP Light On On-Board Diagnostics (OBD)
