chli1976 Profi-Schrauber
29-12-2018, 17:10 Subject: BMW E90 320d: Starting Problems After Long Idle |
I have a 320d that has difficulty starting after being idle for a few hours. The longer it sits, the worse the problem gets.
The battery and glow plugs are fine.
I've also checked the oil feed lines, and when I removed the intake manifold, I replaced all the lines underneath it. I also replaced the O-ring on the metering valve at the high-pressure pump, as it was slightly damp all around.
I also installed a check valve after the filter, as it was the only place where there were no plastic pipes. VCDS
Translated on 26-09-2026, 3:25.
Herbert Profi-Schrauber
29-12-2018, 20:55 Subject: BMW E90 320d: Starting Problems After Long Idle |
Does electricity actually flow through the glow plugs? Can this be measured with a clamp meter? (Or observed through the openings in the spark plug well for the electrostatic discharge electrodes).
I once had a problem with the plugs.
Otherwise, it's heading in the direction of (BMW) diagnostics.
Herbert. Horch A4 8K CJCD
Translated on 26-09-2026, 3:26.
29-12-2018, 22:06 Subject: BMW E90 320d: Starting Problems After Long Idle |
I haven't measured the power consumption, but it should be detectable through the diagnostic system. There's nothing related to this issue stored in the error memory.
Edit: We're currently around 8°C, so it should start right up without needing to be pre-heated. VCDS
Translated on 26-09-2026, 3:27.
