TDI CFHC: Small Batch Adaptation 2.0
Jahresprogramm
Karma: +0 / -1   Thank you, like it!
2012 Volkswagen Golf
Post08-12-2018, 16:45    Subject: TDI CFHC: Small Batch Adaptation 2.0 Quote
I would like to perform a micro-adjustment of the injectors on a Caddy III Kombi 16V 2.0 TDI, manufactured in 2012, or "learn the injector tolerances." Unfortunately, I can't find anything about this in the VCDS basic settings.
Background: I've been noticing increased diesel knocking when the engine is cold. This was similar about two years ago. At that time, a small amount of additive was used to fix the problem, which was administered by a certified workshop. Now, I hope for a similar successful outcome.
Greetings.
Alex.
Log-WV2ZZZ2KZCX139676-125500km.txt
 File name:  Log-WV2ZZZ2KZCX139676-125500km.txt
 File size:  9.04 KB
 Downloaded:  520 times
Translated on 22-08-2026, 18:14.
Post09-12-2018, 10:27    Subject: TDI CFHC: Small Batch Adaptation 2.0 Quote
Please check the adaptation channels in your engine control unit.
Translated on 22-08-2026, 18:15.
dieselschrauber likes this.
Post09-12-2018, 10:38    Subject: TDI CFHC: Small Batch Adaptation 2.0 Quote
Hi there,
Alternative setting: Reset learning values.
Do not change the closing time correction when using the adaptation feature!
What do the values for idle speed correction indicate?
Translated on 22-08-2026, 18:16.
Jahresprogramm
Post10-12-2018, 18:05    Subject: TDI CFHC: Small Batch Adaptation 2.0 Quote
Unfortunately, I couldn't find anything similar (see Screenshot).
Herbert wrote:
Alternatively, default settings > Reset learning values.
What do the values say for the idle correction?
I have some screenshots regarding the quantity discrepancy and closing time correction. Cylinder 2 seems to be behaving differently.
What can be expected when resetting the learning parameters?
Thank you in advance and best regards.
Alex.
 File size:  138.42 KB
 Viewed:  1297 times
 File size:  121.99 KB
 Viewed:  575 times
 Adaptionskanäle
 File size:  171.61 KB
 Viewed:  518 times
Translated on 22-08-2026, 18:17.
Herbert likes this.
Post10-12-2018, 18:50    Subject: TDI CFHC: Small Batch Adaptation 2.0 Quote
What can be expected when resetting the learning values?
The values for the idle speed control are still within acceptable limits.
Do you always get gas at the same gas station? Sometimes, switching gas stations or brands can help if there's a problem (it's rare, but I've occasionally experienced situations where the car behaved strangely after getting gas from the same station).
Translated on 22-08-2026, 18:19.
Jahresprogramm
Post10-12-2018, 20:42    Subject: TDI CFHC: Small Batch Adaptation 2.0 Quote
That means there's no way to trigger the adaptation of small quantities using VCDS, right?
No, but the one we have locally feels like it's the worst. icon_redface.gif icon_lol.gif
Greetings.
Alex.
PS: Lately, a loud clicking sound has been accompanying the cold engine. It sounds like a faulty hydraulic lifter on a gasoline engine... icon_sad.gif
Translated on 22-08-2026, 18:21.
Post10-12-2018, 21:17    Subject: TDI CFHC: Small Batch Adaptation 2.0 Quote
It probably isn't worth it, but take a look at what's possible with the basic settings. I already know about the customization options – consider them given.
Translated on 22-08-2026, 18:22.
No new posts Caddy Idle Speed: CFHC Adjustment Guide Diesel Engine Technology
No new posts CFHC Headlight Indicator Flashes, but No Error Code Appears Diesel Engine Technology
No new posts Caddy: Jerky Engine, G28 Sensor, Low Rail Pressure Diesel Engine Technology
