Repair of a VP37 manifold (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Troubleshooting & Guides
nickknatterton Post06-07-2021, 6:29
Here's the translation:
Content: Brief functional description of the VP37 distributor injection pump, troubleshooting, repair instructions, and various other information. Photos, old drawings, and sketches.
hof.martin (at) gmx.de
Addition from Rainer: Please pay close attention when disassembling to ensure the control slide is oriented correctly on the distributor piston, and reinstall it in the same way!
Specifically for cleaning and disassembling the quantity control unit, see also: https://community.dieselschrauber.org/en/viewtopic.php?t=5517
Zerlegen_des_Verteilerkörpers_einer_VP37.pdf
 Zerlegen Verteilerkörper VP37 als PDF.
 File name:  Zerlegen_des_Verteilerkörpers_einer_VP37.pdf
 File size:  1.28 MB
 Downloaded:  9557 times
Zerlegen_des_Verteilerkörpers_einer_VP37_WEB01.doc
 Diese Anleitung enthält eine kurze Funktionsbeschreibung, eine Fehlerdiagnose, eine Rep.-Anleitung und div. Fotos, Ex-Zeichnungen und Skizzen
 File name:  Zerlegen_des_Verteilerkörpers_einer_VP37_WEB01.doc
 File size:  752 KB
 Downloaded:  51540 times
Ratings - Repair of a VP37 manifold
Average rating: 4.56 - worst rating: 3 - best rating: 5 - number of ratings: 9 - View ratings
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Cushion button repair General Tips
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Problem innerhalb des Gehäuses einer VP37 Diesel Engine Technology
This topic is locked, you cannot edit or reply. Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine... Diesel Engine Technology
No new posts VW 1Z Engine ESP Tax Signal (VP37) On-Board Diagnostics (OBD)
No new posts LMM repair Diesel Engine Technology
