Required coding for AHK _ Passat Alltrack B7
alevuz
Karma: +32 / -0   Thank you, like it!
Post02-04-2019, 19:46    Subject: Required coding for AHK _ Passat Alltrack B7 Quote
We would like to retrofit a tow hitch (from Westfalia, with an electric kit) to the above-mentioned vehicle.
Could someone please tell me the basic steps of coding?
Installation and wiring shouldn't be too difficult... the installation manual is quite comprehensive for that.
Thank you so much!
SG
Manfred.
Log-WVWZZZ3CZDE156379-115410km-Alltrack Mike vor AHK Anbau.txt
 File name:  Log-WVWZZZ3CZDE156379-115410km-Alltrack Mike vor AHK Anbau.txt
 File size:  11.48 KB
 Downloaded:  683 times
Touareg V10 TDI (AYH)
Post02-04-2019, 21:07    Subject: Required coding for AHK _ Passat Alltrack B7 Quote
The general procedures for retrofitting a trailer hitch are very similar.
/viewtopic.php?t=19014&highlight=ahk+encoding
alevuz
Post03-04-2019, 8:20    Subject: Required coding for AHK _ Passat Alltrack B7 Quote
THANK YOU - Rainer !!
No new posts Backup encodings and adjustments with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Inspection Coding & Adjustments On-Board Diagnostics (OBD)
No new posts Touareg Comfort Control Unit - Coding On-Board Diagnostics (OBD)
No new posts Question about some codings in various control units On-Board Diagnostics (OBD)
No new posts Log Passat v6 TDI Raw Upload
