Touareg V10: Bleed Additive System (Coding II)
tueti2
Post15-03-2017, 21:21    Subject: Touareg V10: Bleed Additive System (Coding II) Quote
Hello community,
For a few weeks now, I've been an interested reader in this great forum. Thank you to everyone for all the useful information that can be found here. I would now like to ask a question myself.
As a new VCDS user, I have been exploring the program and came across the following note under "Engine Electronics/Coding II": "29563 = Bleed additive system (2 strokes, see MWB 072/2)". See the two screenshots (hopefully the insertion worked).
I recently added the additive to my Touareg V10 (BLE) myself, but I've never read anything about bleeding the system. I also couldn't find anything about it in the forum.
Does anyone know what "coding-ii" refers to in VCDS? What exactly is being deactivated? Why is it being deactivated? What can happen if you don't deactivate it?
 File size:  60.06 KB
 Viewed:  2097 times
 File size:  73.85 KB
 Viewed:  4511 times
VW Touareg V10, Jg. 2005
Translated on 08-10-2026, 6:06.
dieselschrauber likes this.
Post15-03-2017, 21:58    Subject: Touareg V10: Bleed Additive System (Coding II) Quote
This is only necessary after maintenance work on the system that goes beyond simply refilling the tank. This includes things like replacing the pipe or the pump, especially if air has entered the system.
Translated on 08-10-2026, 6:07.
Karma: +807 / -0   Thank you, like it!
Post18-03-2017, 21:24    Subject: Touareg V10: Bleed Additive System (Coding II) Quote
Translated on 08-10-2026, 6:08.
dieseltech.ch
2008 Audi A4 Avant Consumption
Post03-04-2019, 7:45    Subject: Touareg V10: Bleed Additive System (Coding II) Quote
What does the remaining quantity of -50.80 mean? Why is there a minus sign in front of it?
Arbeite mit AUTEL, LAUNCH X431 PADII, VCDS, und Stardiagnose
Fahre einen Audi A4 B8 mit 3.0 TDI Motor (Motorcode CAPA)
Post06-04-2019, 10:23    Subject: Touareg V10: Bleed Additive System (Coding II) Quote
Hello.
I can only speculate. My guess is that the level sensor has a very low resolution, and the actual fuel level is estimated by the control unit, taking into account the mileage and driving behavior.
Your tank would therefore be less than empty, at least according to the control unit. icon_lol.gif Why don't you simply refuel?
No new posts Fuel system bleeding - Audi A4 3.0 TDI BKN Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg 7L - Need help with coding the onboard network AFL On-Board Diagnostics (OBD)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts Bleed Diesel Filter: How To & Why Diesel Engine Technology
No new posts VE Pump Bleeding: How to Remove Air Diesel Engine Technology
