Golf 4: Recode Brake Electronics for Lift Kit.
cetano
Avatar-cetano
Post23-04-2019, 17:23    Subject: Golf 4: Recode Brake Electronics for Lift Kit. Quote
After I lifted my Golf4 sedan 4Motion 1.9 TDI, 90 hp, with AGR seats, manufactured in 2000, I started experiencing problems with the ESP system.
As reported in other forums, the ESP (Electronic Stability Program) can sometimes activate in extreme left-hand turns on the Volkswagen Golf 4.
It was recommended that the brake electronics be adjusted to match the lift kit, i.e., re-programmed.
No other modifications; wheels are standard (205/55R16, all the same, including tread depth).
I have the following control unit installed (MK20):
Address 03: Brake Electronics
Label file: DRV\1J0-907-37x-ESP-A.lbl
Part number: 1J0 907 379 AB
Component: ESP 20 CAN V005
Coding: 00214
Operating number: WSC 31414
VCID: 71EF8E9D3B2F4AC22A-4B18
Is it possible to use a different encoding than 00214? If so, which encoding should I use?
VCDS does not provide any suggestions when attempting to recode.
The topic has already been discussed here, but only in relation to the MK60.
Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Translated on 29-07-2026, 8:25.
Back to top Profile PM Email
Post27-04-2019, 11:59    Subject: Golf 4: Recode Brake Electronics for Lift Kit. Quote
Recoding of the ESP/ABS system is a sensitive matter from a safety perspective. I would suggest searching on Google for vehicles with your specific VAG part number and comparing the coding information.
In case of emergency, a visit to the icon_smile.gif might help.
Translated on 29-07-2026, 8:28.
cetano
Avatar-cetano
dieselschrauber likes this.
Post28-04-2019, 14:27    Subject: Golf 4: Recode Brake Electronics for Lift Kit. Quote
Yes, there are very few parts left that were originally installed in the Golf 4 4Motion.
Regarding icon_smile.gif, I find it difficult... It's been decades since I was there, and my knowledge is only tangential, having only seen the results of what goes on there.
Ross Tech inquiry: initial response, then silence. I thought something similar to the support for MK60 might be coming.
I'll probably have to recalibrate everything and then figure something out... It's my winter car; thankfully, my 124 doesn't have anything like that.
Thank you.
Best regards, Hartmut.
Translated on 29-07-2026, 8:29.
No new posts Doku keine Umcodierung möglich, 01K-01F Automatikgetriebe Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented clutch failures in 4-Motion TDI-PD engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mehrleistung durch Umcodierung! Diesel Engine Technology
No new posts Bremsenelektronik: keine oder falsche Grundeinstellung On-Board Diagnostics (OBD)
No new posts Steuergerät für Bremsenelektronik codieren- Hilfe benö... On-Board Diagnostics (OBD)
No new posts Polo Blue Motion - BMS Upload
