VCID Meaning: Explained in ECU Log Files
amishorty
Karma: +9 / -1   Thank you, like it!
2004 Volkswagen Passat
Post08-05-2019, 19:33    Subject: VCID Meaning: Explained in ECU Log Files Quote
Hi everyone,
I would like to know what the abbreviation VCID stands for.
The listing at address 01 for the motor electronics looks like this:
Part number:
Component:
Revision:
Encoding:
Operating number:
ASAM Dataset:
ROD:
VCID:
What does this VCID mean?
Could it possibly be called "Version Code Identification"?
Who can enlighten me?
The reason I'm asking is as follows:
The Audi A6 was purchased in 2015.
In early 2017, he took his car to Audi for an inspection.
In early 2018, I wanted to postpone the "service," which was still possible in 2016.
However, in 2018, it was no longer possible to use VCDS, Bosch, or a Japanese software solution for all cars.
Everything was identical, as listed above.
Only the VCID had a different sequence of numbers.
What does that mean?
Sure, I'd be happy to help.
HG
Michi.
Translated on 15-09-2026, 2:36.
Karma: +805 / -0   Thank you, like it!
Post09-05-2019, 19:07    Subject: VCID Meaning: Explained in ECU Log Files Quote
The VCID is only used for debugging the diagnostic program and does not originate from the control unit.
Translated on 15-09-2026, 2:38.
No new posts Boost Gauge: Essential for Every TDI Engine Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Component protection active since the control unit was re... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Should the water pump definitely be replaced? Diesel Engine Technology
No new posts Log files for 1.9 TDI BKC engine Upload
No new posts Log Files: 2003-08-11 Upload
