vag-driver Profi-Schrauber
19-08-2019, 8:10 Subject: Lubricate hinges and sliding rails |
What type of grease do you use to lubricate door hinges and the mechanisms of panoramic sunroofs? VW reportedly uses a special grease for panoramic sunroofs to prevent sticking and hardening. Viele Grüße
Andreas
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
dieselschrauber likes this. |
20-08-2019, 9:48 Subject: Lubricate hinges and sliding rails |
Hey,
For all hinges, I use a Teflon spray from Makra.
With the panoramic sunroof, I can only guess that you need to use a specific type of grease. The rails should be cleaned thoroughly and then re-lubricated.
I had several customers who, due to lack of or improper maintenance, complained that the sunroof was no longer opening and closing correctly.
Best regards, Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
20-08-2019, 10:38 Subject: Lubricate hinges and sliding rails |
klahaui wrote: |
With the panoramic sunroof, I can only guess that you should use a specific type of grease; the rails will be cleaned thoroughly and then re-lubricated. |
Can I buy the oil from VW? How and with what is the cleaning performed? Viele Grüße
Andreas
20-08-2019, 19:07 Subject: Lubricate hinges and sliding rails |
There are original part numbers for the cleaner and lubricant, but unfortunately, it's been too long for me to provide you with more specific information. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
Herbert Profi-Schrauber
20-08-2019, 19:50 Subject: Lubricate hinges and sliding rails |
on the A4 8K
VAS 6764 Cleaning and degreasing tool.
Cleaning solution for seal D009 401 04.
Grease for seal G 052 141 A2.
Lubricant paste (cartridge) for rails G 060 751 A2.
Herbert. Horch A4 8K CJCD
21-08-2019, 8:17 Subject: Lubricate hinges and sliding rails |
Herbert wrote: | Hi,
on the A4 8K
Herbert |
I have now also found this information online. However, for my Sharan, I need the grease fitting VAS6621, but it is not readily available. And without this scraper, cleaning wouldn't make any sense. Viele Grüße
Andreas
21-08-2019, 21:58 Subject: Lubricate hinges and sliding rails |
And why don't you order it through Erwin?
22-08-2019, 7:20 Subject: Lubricate hinges and sliding rails |
Herbert wrote: | And why don't you order it through Erwin?
Herbert |
Do they also sell to private individuals? Viele Grüße
Andreas
