Polo 9N 1.4 TDI: RPM/Engine Speed Issue
Marco_Gorski
Post31-05-2019, 0:12    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
Hello diesel mechanics,
I'm having a problem with my Polo 9N, manufactured in 2003, with engine code BAY.
I don't have any problems when accelerating. The problem arises when...
"For example, I'm driving on a country road. I put it in 5th gear and then accelerate fully. Then, what you see in the video happens. There are no error messages anywhere. Maybe someone has seen this phenomenon before."
I'm leaning towards it being the clutch, but could it be something else?
Polo 9N 1.4 TDI: RPM/Engine Speed Issue - IMG_7218.MOV
 File size:  114.81 MB
 Viewed:  464 times
Translated on 25-09-2026, 5:59.
dieselschrauber likes this.
Post31-05-2019, 9:00    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
This phenomenon has accompanied me for 12 years with my Golf 4.
/viewtopic.php?t=11027&highlight=clutch+axr
/viewtopic.php?t=16607&highlight=clutch+axr
Translated on 25-09-2026, 6:00.
Post31-05-2019, 12:39    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
Hello.
The clutch is slipping... although, considering it has 370,000 km on the odometer, it's not really surprising, as it's probably worn out.
Translated on 25-09-2026, 6:01.
Marco_Gorski
Post31-05-2019, 12:41    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
I had replaced the clutch. It worked fine for 4 weeks, and then the problem came back.
I will take a look at the posts that Bertil has made.
Translated on 25-09-2026, 6:02.
Marco_Gorski
Post31-05-2019, 18:51    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
I'm going to install a new clutch slave cylinder first.
I'll report back later.
@Rainer
As mentioned above, I'm pressing the clutch, but what else could it be? icon_question.gif
Post31-05-2019, 19:43    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
Marco_Gorski wrote:
As mentioned above, I'm pressing the clutch, but what else could it be? ...
Damaged crankshaft.
Too much lateral play or misalignment, causing the pressure plate to be pushed down.
You can skip the receiver cylinder. It only helped me for a short time.
Translated on 25-09-2026, 6:03.
Karma: +1344 / -0   Thank you, like it!
Post01-06-2019, 7:18    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
The amount of clearance in the release bearing should be significantly greater than any potential axial play in the crankshaft. Furthermore, any axial play in the crankshaft would contribute to additional, potentially fluctuating, "play" in the clutch.
When the clutch pedal is in its resting position, the balancing hole is open, which means that when the clutch is not engaged, it automatically adjusts in either direction.
The clutch may slip if there is insufficient pressure applied, or if the friction material has poor properties. A dual-mass flywheel (DMF) can also "slip" if the friction linings wear down (if that type of DMF is present). This could also explain the occasional slipping.
The engine type, or the parts available for power transmission, seem to have a fundamental problem. The replacement procedures described in the posts suggest this.
Is there a conversion option for the engine to use EMS? That would be a way to stop all the troubleshooting.
Translated on 25-09-2026, 6:04.
Marco_Gorski
Post01-06-2019, 8:03    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
Hello everyone!
Thank you very much for getting this far.
Okay, so according to the AKTE system, there's no mention of a dual-mass flywheel (ZMS). It only lists the flywheel. The part number is 045105269.
That wouldn't be a wrong assumption. The flywheel also experiences wear and tear. Given the mileage, this would be a plausible explanation.
I will let you know when I'm ready.
Perhaps one of you knows whether this is a ZMS icon_smile.gif.
Translated on 25-09-2026, 6:06.
Post01-06-2019, 8:42    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
Marco_Gorski wrote:
Okay, according to the records, there is no mention of a ZMS.
He didn't either.
Translated on 25-09-2026, 6:07.
Post03-06-2019, 12:17    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
The fact is, whether it's the clutch disc or the flywheel, the surface can be glazed, which means the new clutch will be damaged again in a short amount of time.
Translated on 25-09-2026, 6:08.
Marco_Gorski
Post28-06-2019, 1:59    Subject: Polo 9N 1.4 TDI: RPM/Engine Speed Issue Quote
Rüdi wrote:
The fact is, whether it's a ZMS or a dual-mass flywheel, the surface can be glazed, which means the new clutch will also be worn out quickly.
Hello Rüdi.
Regarding the crankshaft, is the imbalance specific to it, or is it a general issue?
I had replaced the clutch slave cylinder. The problem was temporarily better/gone. Now it's back again...
Oh man... what should I do?
Does anyone have any advice?
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Polo TDI: Specs, Features, & More Diesel Engine Technology
No new posts Polo 6R On-Board Diagnostics (OBD)
No new posts Polo 86c, year of manufacture 1992 Gasoline Engine Technology
No new posts Polo TDI: Specs, Problems, & Common Issues Diesel Engine Technology
